Ok, then I will wait until then.
It looks like there are problems with preparing the description text and the changelog. Can you run these two commands:
html2text --version
awk --version
⦠and post the output?
I also fixed some typos in your config: Systemli Paste
Your commads led to errors.
Anyway, it wasnāt to hard to get the wanted output
awk -W version
mawk 1.3.4 20200120
Copyright 2008-2019,2020, Thomas E. Dickey
Copyright 1991-1996,2014, Michael D. Brennanrandom-funcs: srandom/random
regex-funcs: internal
compiled limits:
sprintf buffer 8192
maximum-integer 2147483647
html2text -version
This is html2text, version 1.3.2aThe latest version can be found at http://userpage.fu-berlin.de/~mbayer/tools/
This program is distributed in the hope that it will be useful, but WITHOUT
ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
Thanks
This means youāre using different versions than me (i.e. different tools, to be precise). Iām using GNU awk and this html2text⦠Iāll have to find a way to make the script compatible with different versions. Iām surprised thereās such a difference between mawk and gawk.
html2text is the version which ships with my Distro (KDE neon - ubuntu LTS based) there is no other version in the standard repos. Regarding awk, mawk and gawk are both available.
I havenāt had the time yet to investigate what exactly breaks compatibility with mawk.
For me itās the same situation just with a different implementation⦠This is not too big of a problem though, I will update the script so it falls back to copying the input as-is without converting it.
I wanted to install Patch: Configurable keyboard height on my Xperia XA2 without patch manager. I get the following error message: ** Command ārpmā not found.
Is there a solution?
Where did you download, how did you try to install it?
Download: Patch: Configurable keyboard height | OpenRepos.net ā Community Repository System
Install with the app file management and then with the button install
Regarding the patch: the easiest way is to install it from Patchmanagerās web catalog. Open the Settings app, go to Patchmanagerās settings page, then select āWeb Catalogā from the top pulley menu. There you can search for the patch and install it.
IIRC, this error message is only related to the file preview, not to the actual installation. I assume you installed File Browser from Jolla store? If so, I recommend you install Storeman and then install File Browser through the Storeman app (as well as the patch if you didnāt install it from the web catalog).
āThis patch is incompatible with the installed SailfisOS version.ā Hahahahā¦
Uhh⦠what version are you on?
If you are on the latest release that was published just recently, then you may have to enable the option that allows installing āincompatibleā patches in Patchmanagerās settings. The patch should be compatible but Iām traveling at the moment and wonāt be able to test it.
No problem, I did not know about this possibility. I will test it.
EDIT: Nothing I set unfortunately changes the keyboard, no matter if reset or device restart.
Once the patch is activated you donāt hve ro restart anything.
What scaling have you set?
For me it is working flawless. Iām on a Xperia 10 II running SF 4.5.0.21.
60% looks like that:
150% like that:
I would also like to have it like that and have tried it again. But nothing changes whether I set 60% or 120%.
So which SFOS version are you running? The keyboard changed in recent updates, so if youāre not on the latest version then itās quite possible that the patch is actually incompatible.
Hi @ichthyosaurus
just wanted to say, that iām waiting for you, that you update the patch.
Just in case, that you think, Fellfrosch promised to write documentation and doesnāt.
I definitively will. When all went through without errors.
If you are short of time at the moment, take all the time you need, there is absolutely NO hurry. (The patch is running for me anyway - at least as reliable as fingerprint unlocking)
I just wanted to avoid that we both think, itās the other oneās turn.
Were you ever able to figure this out? Iād love to try partnerspace but I donāt want to give up no home carousel.
Unfortunately, I never found the time
