Office suite for SFOS?
A quick fix for your 2 points above is now ready for download here. In both cases the fix will only work on new sheets. The release number is unchanged.
Thanks. And I hope for more findings!
Ielig Calc 0.5.0
Sum function doesn’t work. Any idea?
Use a colon for range a1:a2. Use =a1+a2 without the SUM function for individual cells.
Thanks, that did the trick.
I’ve just learned that you can even tap the beginning and end fields of the range and then the result field, all after choosing the Sum function. :wink:
