Naming of Dual SIM cards
Hi Nephros,
Good morning. Hope all is well with you today. The site is finally back up today, but unfortunately this patch does not install correctly through Patchmanager on my Xperia 10 III. The reason is my Sailfish OS version is 4.4.0.68 which is not a supported version. Nevertheless, I’m almost positive it will work if I apply it manually. I’ll give that a go after work today and let you know the outcome. Thanks again for all your help. I hope that Jolla incorporates this officially at some point as it’s a simple but very useful customization for several use cases.
Thanks again
Confirmed. Manual application was successful on 4.4.0.68. It also installed successfully (with converted paths) through Patchmanager with the ‘allow incompatible patches’ option enabled. Great work, thanks for this!!!
I have updated the compatability specification in the web catalog.
It will not show up for existing installs, but new ones will see it as compatible (you may uninstall and install the patch form the catalog to have it show up as compatible).
