Idk where you heard that cause I don’t lol
thanks for the squeezebox plugin !
tried it just now using the ip adress and can’t connect.
squeezer can connect.
i get Connection refused. Are you enforcing https ?
i run my local squeezebox server (now called lyrion) without
My squeezebox server is http and it works fine. You sure you typed correct port? I’m also using lyrion
copied them from squeezer, port 9000, which also works for the browser..
hmm problem must have been between the ears. test connection works.
thanks
Last week i was able to add a squeuuzebox plugin, but everything remained empty
Today i did try again, started app, the wifi on phone and would see my player with current song, empty playlist and the local files on sq server.
The remote would allow to adjust volume and sync button is there
Ckicking on a folder in files would crash the app.
After restart i am back to state of last week: all empty
Update: test connection on plugin, shows players again.
I can pause player/ play player (playing radio), current title does not get updated
Will play around and report
Ok, not all folders do crash
Is there a debug-log to enable?
In our company our lyrion-server is displayed (correct ip on port 9000). Pressing Test gives ok result. Connection doesn’t work (protocol error).
I’ll be honest I did not have single issue with squeezebox, i’ll search for ways to get some debug info for ya guys
Another idea is that our lyrion server is configured other like the usual way, i look into it on next monday.
Okay so musikilo uses jsonrpc api described here. My installation doesn’t have login/password protection not sure about yours (musikilo doesn’t even have those fields).
For simple test you can do
curl -g -X POST -d '{"id":1,"method":"slim.request","params":["00:04:20:ab:cd:ef",["player","count","?"]]}' http://server:9000/jsonrpc.js
see if that works, it should contain response with "result":{"_count":<count>}. If that works, musikilo should work as well. Make sure the phone can access the server, as fallback you can try using SqueezeR it uses same thing, or use website, it also uses same api. The url is hardcoded http if thats an issue. If musikilo encounters any issue while sending request it will echo it (so you can run it from terminal and see) and also display error page. Hope that helps. You can also enable debug logging in lyrion server and see what it says
@pawel.spoon If you dm me and have some time i’m sure we could debug it swiftly
Guys, since musikilo is more of a media controller rather than media player now, if you have any media player or something that you wish you could control from a phone via musikilo, give me the name and I can add it as a plugin.
Currently I plan to add kodi (for myself) and Tauon per @247’s suggestion
Basically if you have folder view + current playlist + media controls, i can add it as plugin to musikilo
I am now not familiar with all functions of that application, sorry if that was discussed already:
I have some raspberries with logitech media server running. Can this app control them?
Squeezebox is already in yes
How to setup this plugin? If I put http://lokal.ip:9000 I always have connection error in the app
Edit: after i addet host without http and reentered 9000 as port in looks connected.
Musikilo update is out with kodi and tauon plugins!
I couldn’t find someone to test kodi plugin so please report on how does it work for you. For me it was bit buggy (kodi’s fault) when removing items from the queue, but if you stop first then it should be no issue. I also cannot add directory to play (like dvd directory) but files work fine, but when I asked kodi guys about it i got silence so i guess it is what it is
Now someone wants me to add subsonic plugin which should be done in day or two
Currently we’re also pondering spotify, without running librespot, just as a controller. Could be done with like “your library” and then selecting a playlist
let me know if you think i should do it
By the way, “let me know” is not just hitting like, I need actual responses if it is okay with your use-case
I am usingbonly Squeezebox control for my 3 raspberries and 2 logitech radios. It works great so far. One point is what i am missing now only is: i can only use my existing playlist, but not myfavorites to add them to the playlist.
yeah I only use files in music players, no library or playlists. Tho maybe I could add loading playlists if i acted as if they’re files (sometimes they are i think mpd stores playlists in files)
but that’s what you mean right? cause i didn’t get full meaning of what you were trying to say
I need to make some screenshots on PC and provide you more detailed info about possible workflow. But i need some days for that.
