Yes, it worked. Now I’m playing a bit around with Android 11 but … what the heck … since my last Android experience (Lineage on Fairphone 2) there has changed some stuff. Not in a good way. Strange gestures. Annoying notifications which can’t be muted or dismissed. It turns totally crazy when you disable Play Services. The pull-down menu is absolutely messy.
Now I understand why screens become bigger and bigger - you need that much space to see the interesting things between all the unnecessary stuff ![]()
@nasi @multispeedlurker Thanks for joining the discussion! I hope the unlocking services become available soon™️!
Can you folks and/or @pansen-jim comment on the standby power drain with and without wifi? Like percentage/hours, and which Android version you used. I might need to start looking for “other wifi drivers” if that is even possible, the current one makes the device last only a day if wifi is on… Thanks!
Thanks. I asked the customer support via their contact form. I’ll report back.
I’m not at home atm, but I can start checking on Monday. In principle, I don’t really want to use it with Android
But checking standby-time is something which I will be able to endure.
Thanks for your efforts, if I can manage to unlock, it will surely be a nice device!
Of course measure this at your own pace. Just as I am updating here.
I should also study how to install without needing twrp, but ping me if you need to install sooner than I do that, there are some instructions on Sailfish on Zenfone 8 · GitHub but they probably need more love.
Thanks!
Do you have an idea how to prevent auto-upgrading? As soon as I switch on wifi, this stupid Android starts downloading the upgrade
Do you think it is necessary that it is connected to a wifi? Or would it be sufficient to have it switched on but not connected?
Switched on but not connected is fine.
There must be a setting next to the one checking for updates, to automatically upgrade over wifi, that can be switched off
Settings → System → System Update → Gear Icon in upper right corner
But for some reason it was greyed out when I tried to set it. Later I came to this setting via the update notification and it was not greyed out. I’ve deactivated automatic update, now it’s greyed out again. Pretty strange.
And it’s still asking very often if it should resume update. Annoying.
I disabled or removed most of the standard apps (Gmail, Maps, Play Store etc.) but Play Services are still enabled. I’ve charged to 80% and phone was just lying around.
With WiFi enabled and connected I was on 78% after 4hrs and 73% after 20hrs.
With WiFi disabled I was on 79% after 4hrs and 73% after 26hrs.
I’ve installed “BatteryBot Pro” which said 22hrs until drained on 80% without WiFi and 19hrs until drained on 80% with WiFi enabled.
EDIT: now BatteryBot Pro tells me there are 5days 11hrs left until drained while having 72% battery. Maybe this measurement is not very reliable or it’s still “learning”.
I think that measurements by me are not longer needed which makes it possible for me to let the phone switched offuntil an unlock becomes possible again
Thanks @nasi - so I guess Asus firmware does not have the wifi drain problem… need to diff their OSS kernel with the one used in lineage and parameters used for the module…
Indeed @multispeedlurker, no need to switch it on
Day 19
What FingerprintInscreen does on this device is: android_device_asus_sake/fod/FingerprintInscreen.cpp at lineage-18.1 · LineageOS/android_device_asus_sake · GitHub
But then:
# ls -l /proc/globalHbm
-rw-rw-rw- 1 system system 0 May 14 00:59 /proc/globalHbm
I have to change it so that defaultuser can do this, since lipstick, sailfish-fpd-community-test etc are run as an user.
But even running manually # echo 1 > /proc/globalHbm and # echo 0 > /proc/globalHbm does not get me a useful output.
vendor.goodix.sensor.status changes from 3 when idle to 4 when enrolling.
# cat /proc/driver/fp_xy always returns 0,0
Found something.
In kernel.
# cat /sys/devices/platform/soc/990000.i2c/i2c-1/1-0038/fts_fp_mode
Notify FP:Off
Echoing 1 goes “On”
Also echo 1 > /sys/devices/platform/soc/990000.i2c/i2c-1/1-0038/fts_fp_ctrl_mode
makes the touchscreen NOT work but emit:
/dev/input/event8: 1684183261.138 - 0x01/EV_KEY - 0x021/KEY_F - 1
/dev/input/event8: 1684183261.138 - 0x01/EV_KEY - 0x021/KEY_F - 0
/dev/input/event8: 1684183261.889 - 0x01/EV_KEY - 0x016/KEY_U - 1
/dev/input/event8: 1684183261.889 - 0x01/EV_KEY - 0x016/KEY_U - 0
when fingerprint sensor is touched, and
/dev/input/event8: 1684183259.775 - 0x01/EV_KEY - 0x026/KEY_L - 1
/dev/input/event8: 1684183259.776 - 0x01/EV_KEY - 0x026/KEY_L - 0
/dev/input/event8: 1684183260.358 - 0x01/EV_KEY - 0x016/KEY_U - 1
/dev/input/event8: 1684183260.358 - 0x01/EV_KEY - 0x016/KEY_U - 0
when it is clicked outside.
There’s also “echo 2” to it which seems to make both touchscreen and fingerprint sensor work.
Logs when enrolling seemed to work, by treating 10 as onDown, and adding multiple times fingerprints (the first one made progress without me touching the screen). (sorry, no logs as no paste service allow this big…)
05-15 21:31:08.034 6723 7877 D [GF_HAL][DataSynchronizer]: [onMessage] message.msg=7
05-15 21:31:08.034 6723 7877 D [GF_HAL][DelmarSensor]: msg : 7
05-15 21:31:08.034 6723 7877 D [GF_HAL][DelmarHalDump]: [onEnrollEnd]DUMP_OP_ENROLL dump is disabled.
And the start of it?
05-15 21:30:37.359 6723 7877 D talog : D [gf_algo_common][gf_algo_enroll] group_id=0, finger_id=3112954849, samples_remaining=19
The previous log was made by whitelisting some pids.
Let’s do the reverse, blacklist the noise.
/usr/libexec/droid-hybris/system/bin/logcat | grep -v therm | grep -v wpa_supplicant | grep -v KTOP | grep -v "\[BAT\]\[CHG\]" | grep -vi battery | grep -v light_polli | grep -v "Synchronizing SCSI" | grep -v 26913 | grep -v 19308 where the number is sensors-hal
And
journalctl -f | grep -v "\[BAT\]\[CHG\]" | grep -v "Synchronizing SCSI" | grep -v BSSID | grep -v light_polli | grep -vi battery | grep -v KTOP | grep -v ngfd | grep -v cs35l45
Also tried from some asus rog lineage 19.1
/ # setprop vendor.asus.touch_control_aod 1
/ # setprop vendor.asus.touch_control_fod 1
/ # setprop persist.vendor.asus.fp.wakeup true
[GF_HAL][FingerprintCore]: [onEnrollError] fp property_set 2
[GF_HAL][CustomizedFingerprintCore]: [notifyAcquiredInfo] transfer acquired info: 1005 to customized: 1000.
[GF_HAL][FingerprintCore]: [onEvent] event = 4 workstate = 2
[GF_HAL][CustomizedFingerprintCore]: [notifyAcquiredInfo] transfer acquired info: 1003 to customized: 1002
[GF_HAL][FingerprintCore]: [onEvent] event = 2 workstate = 2
[GF_HAL][FingerprintCore]: [onAuthDownEvt] Auth Down.
[GF_HAL][CustomizedFingerprintCore]: [notifyAcquiredInfo] transfer acquired info: 1002 to customized: 1001
[GF_HAL][FingerprintCore]: [enroll] Enroll.
[GF_HAL][CustomizedFingerprintCore]: [notifyAcquiredInfo] transfer acquired info: 1001 to customized: 1010.
[GF_HAL][FingerprintCore]: [notifyAcquiredInfo] acquired_info=1010
watch -n 1 cat /sys/class/drm/fod_touched
changes only from 0 to 1, you need to echo 0 back
Need to let go fingerprint for now, until I have new ideas.
Let’s make a roundup of other problems:
ramdump device should look like “md_%s” according to drivers/soc/qcom/subsys-pil-tz.c
The “Fatal error on modem!” is a generic “Fatal error on %s!” in subsys_err_fatal_intr_handler in the same file.
I think the important stuff is
(CPU:0-pid:182:irq/335-smp2p) [18:30:57.000940032] modem subsystem failure reason: rmts_api.c:2304:[2, 3145728, -919099608] EFS:rmts_get_buffer failed while writing.
There is no rmts_api.c though :o_O:
Build a recovery inside hybris boot?
We could reverse the “if(ForceNormalBoot)” which used to switch root to “/first_stage_mount” and copy a recovery root there.
But that also means that the modules from vendor_boot.img need to be compatible with the kernel.
I just tested that the one in /vendor/lib/modules/ does not insmod and it has the same file size as the one in vendor_boot:
-rw-r–r-- 1 root root 520576 Jan 1 2009 /vendor/lib/modules/focaltech_fts_zf.ko
But, I could copy mine in there.
Actually, if I think about it, I could copy the recovery image inside the vendor_boot partition :hmm:
But… I think Lineage itself hardly booted with my kernel… what are the chances a recovery would :scratches-head:.
Let’s look a bit at wifi…
# cp /vendor/firmware/wlan/qca_cld/WCNSS_qcom_cfg.ini /etc/
gDot11Mode=1
mount -o bind /etc/WCNSS_qcom_cfg.ini /vendor/firmware/wlan/qca_cld/WCNSS_qcom_cfg.ini
(nope, no difference, but sounds like a good idea to have this in /etc to play with anyway)
FPS
# cat /sys/firmware/devicetree/base/soc/qcom,mdss_mdp@ae00000/qcom,mdss_dsi_sharp_qsync_wqhd_cmd/qcom,mdss-dsi-panel-name
Sharp 2k cmd mode qsync dsi panel
# cat /proc/driver/panel_fps
cat /sys/class/drm/card0-DSI-1/modes
1080x2400x60x183357cmd
1080x2400x90x183362cmd
1080x2400x120x183357cmd
Hmm I think the composer needs to set this to > 60. It is not a file to be written, but some calls to be made.
If unlocking became possible again, would the drain under LOS be of interest?
As I said, they have contacted support. Freely translated was the answer:
According to the Software Specifications, we were able to determine that your phone is intended for further support with firmware like Unlock Device after all.
Expect the update of the firmware support website in coming weeks.
And as was wondering why the maintenance was still ongoing although May 2nd was over, it was obviously a misinterpretation by me:
The maintenance has just started on May 2.
So there is hope.
By the way, how would you rate it? Are you confident (apart from the wifi problem) that it will be a daily-driver capable port?
If halfway decent pictures are taken (within the limits of what is possible with SFOS…), mobile data, telephony, encryption and waydroid work, that would be a really cool duo: the halfway compact phone (one-handed operation, yippie!) and SFOS…
By the way (number 2): in the Asus forum, many people complain about echoes in speaker mode. Have you noticed any problems there?
Sure, if time allows. It would help differentiating between driver issue or userspace services.
Thanks for following up on unlocking with Asus!
I am probably more resilient to bugs and might be more comfortable to wait for the right time to debug or new idea for a bugfix, so I’m not the best person to answer this:)
But the answer is yes, I can daily drive this. I have not really done this with my main SIM card yet and have not took it out more than a couple of days, mostly because I am preparing to reflash it if I change the way I build the image (I’m considering learning how to build a LVM image that would mean a re-flash will be necessary)
However I did test shortly the speaker call, by placing the Zenfone on spearker in another room and “talking” to it from far away and I don’t think there was echo. I should try with a real person to help me, but the echo I had on my previous port when the Android audio services were (intentionally) left running was not there.
Looking forward to trying this out
Thanks for putting the work in!
Day 20, Season 2
Waited one second for vendor.qti.hardware.cacert@1.0::IService/default
When did that start.
Looking at video decoding:
/usr/bin/pulseaudio: Failed to fetch the lookup information of the device 0000000F
ACDB-LOADER: Error: ACDB_CMD_GET_AFE_INSTANCE_COMMON_TABLE_SIZE Returned = -19
0-pid:3334:irq/401-cs35l45) [21:38:57.709438493] cs35l45 5-0031: Global enable assert detected!
3-pid:10086:droid-sink-deep) [21:38:57.715544747] cs35l45 5-0031: Timeout waiting for MBOX ACK
3-pid:10086:droid-sink-deep) [21:38:57.715561562] cs35l45 5-0031: MBOX failure (-110)
ps aux | grep 6252
6252 mediacod {vendor.qti.medi} media.hwcodec /vendor.qti.media.c2@1.0-service
First there’s CCodec saying
The CCodecBuffer saying more or less the same thing
And in between:
05-21 21:38:58.056 6252 1286 E QC2V4l2Codec: [avcD_26] ? is not a supported pixel format!
05-21 21:38:58.148 1192 68 E ion : ioctl c0044901 failed with code -1: Inappropriate ioctl for device
05-21 21:38:58.150 1192 67 E FMQ : grantorIdx must be less than 3
05-21 21:38:58.151 6252 6252 E FMQ : grantorIdx must be less than 3
05-21 21:38:58.152 6252 6252 E ion : ioctl c0044901 failed with code -1: Inappropriate ioctl for device
And after:
05-21 21:38:58.167 1192 66 D AsyncCodecSource: [c2.qti.avc.decoder] Output format changed! Buffers remaining: 0
05-21 21:38:58.197 1192 73 I DroidMediaCodec: Format changed from codec
05-21 21:38:58.197 1192 73 I DroidMediaCodec: notifySizeChanged: width = 1280, height = 544
05-21 21:38:58.245 1192 67 E DroidMediaBufferQueue: Client wasn't able to handle a received frame.
05-21 21:38:58.273 1192 72 E BufferQueueProducer: [DroidMediaCodecBufferQueue](id:2000000000,api:3,p:32,c:32) cancelBuffer: BufferQueue has been abandoned
And in before:
05-21 21:38:58.027 6252 8139 I vendor.qti.media.c2@1.0-service: missing struct descriptor #Param::CoreIndex(-Vc010) for field window of struct #Param::CoreIndex(FV1c00d)
05-21 21:38:58.027 6252 8139 I vendor.qti.media.c2@1.0-service: missing struct descriptor #Param::CoreIndex(-Vc01a) for field misr_info_top_field of struct #Param::CoreIndex(-Vc01b)
05-21 21:38:58.027 6252 8139 I vendor.qti.media.c2@1.0-service: missing struct descriptor #Param::CoreIndex(-Vc01a) for field misr_info_bottom_field of struct #Param::CoreIndex(-Vc01b)
05-21 21:38:58.027 6252 8139 I vendor.qti.media.c2@1.0-service: missing struct descriptor #Param::CoreIndex(--002) for field mastering of struct #Param::CoreIndex(--180a)
Sometimes later
05-21 21:38:58.320 6226 4951 D qdgralloc: Falling back to default YUV format - no camera/video specific format defined, usage 0x100
05-21 21:38:58.321 6252 8136 D qdgralloc: Falling back to default YUV format - no camera/video specific format defined, usage 0x100
05-21 21:38:58.376 1192 49 W qdgralloc: Unknown Color primary = 2
This is all in /vendor/lib64/libgrallocutils.so
However this is not used # lsof /vendor/lib64/libcodec2_vndk.so
One more time:
05-21 22:56:58.788 29187 68 W ColorUtils: expected specified color aspects (0:0:255:255)
05-21 22:56:58.791 29033 29033 E StandardCaps: Failed to read platform hdr value
Also /vendor/lib64/libqcodec2_v4l2codec.so
Has “Failed to read platform hdr value”
Service is:
/vendor/etc/init/vendor.qti.media.c2@1.0-service.rc
Wifi
Searching “power” in drivers/staging/qcacld-3.0/**/*cfg*.h
gRuntimePM=0
* 0: RTPM disabled, so CxPC aware RTPM will be disabled as well
* 1: RTPM enabled, but CxPC aware RTPM disabled
* 2: RTPM enabled and CxPC aware RTPM enabled as well
/sys/class/power_supply/battery/current_now seems to pass below -200k, so raising?
enable_qmi_stats defaults to * 1: Periodic stats over QMI is enabled
enable_qmi_stats=0
drivers/staging/qcacld-3.0/components/mlme/dispatcher/inc/cfg_mlme_powersave.h
gPowerUsage defaults to Mod
gPowerUsage=Min
apsd_enabled - Enable automatic power save delivery - defaults to 0
apsd_enabled=1
This ini is used to enable/disable WoW
gEnableWoW=0
gExtWoWgotoSuspend - Enable/Disable Extended WoW
gExtWoWgotoSuspend=0
Interesting comment:
* hdd_override_all_ps() - overrides to disables all the powersave features.
* @hdd_ctx: Pointer to HDD context.
* Overrides below powersave ini configurations.
* gEnableImps=0
* gEnableBmps=0
* gRuntimePM=0
* gWlanAutoShutdown = 0
* gEnableSuspend=0
* gEnableWoW=0
I have:
- gEnableImps absent, defaults to 1
- gEnableBmps absent, defaults to 1
- gRuntimePM=0, I needed to enable it
- gWlanAutoShutdown, absent, defaults to 0, seems to disable wifi (max is 24hrs == 86400 seconds)
- gEnableSuspend, absent, not found in drivers
- gEnableWoW absent, defaults to 3, I need to disable it
…Plus, I have enabled gRuntimePM=2 for now, let’s test until tomorrow…
ended up with
gPowerUsage=Min
apsd_enabled=1
gEnableWoW=0
(tommorow test - still heavy drain, 200-500mA)
Back to video playback:
May 23 00:42:40 Zenfone8 dbus-daemon[9021]: library “libandroidicu.so” needed or dlopened by “/usr/libexec/droid-hybris/system/lib64/libmedia.so” is not accessible for the namespace “(default)”
mal suggests dont-use-droid-convert. Doesn’t work.
Elros suggests I can navigate to file:/// and browse to the video to test with the browser. Works
But what can I do about that?
rm /odm/lib64/libandroidicu.so
touch /odm/lib64/libandroidicu.so
mount -o bind /apex/com.android.art/lib64/libandroidicu.so /odm/lib64/libandroidicu.so
rm /odm/lib64/libicuuc.so
touch /odm/lib64/libicuuc.so
mount -o bind /apex/com.android.art/lib64/libicuuc.so /odm/lib64/libicuuc.so
rm /odm/lib64/libicui18n.so
touch /odm/lib64/libicui18n.so
mount -o bind /apex/com.android.art/lib64/libicui18n.so /odm/lib64/libicui18n.so
Then:
A lot of buffers are being dropped.
(That happened even before though)
" [avcD_27] YV12 is not a supported pixel format!" in browser vs “[avcD_14] ? is not a supported pixel format!” in Gallery
https://pastebin.ubuntu.com/p/TWn75y3gNC/
Browser plays the video. Gallery does not.
It’s
vs
Probably that would be too easy, but there is a page that describes an unlock simply via fastboot:
https://mobilewithdrivers.com/download/unlock-bootloader/asus-zenfone-8-zs590ks
Of course it’s possible that this is just an automatically generated page and the procedure doesn’t work…
Does anyone see a risk in just trying this?
What could happen in the worst case? That it does not work? Or that it ends up being a brick?
Yes. Please don’t link such crap.
If you could brick it in normal menus ASUS would have gone bankrupt from warranty claims.
Menus? I’m talking about fastboot which isn’t a menu, at least as far as terminals don’t count as menus. Maybe some people(you?) count everything that is easier than assembler as menu, but I certainly don’t agree with that.
