So I tested ISODrive-0.5.2-1.12.1 and it works, list ISOs also on sdcard. Thanks again. The only difference now from ISODrive on 4.4.0.64 and older versions of SFOS is that before it listed ISOs from all (sub)folders on device and sdcard, but that is detail and not much important.
edit: I will try also the version from your second post.
I got an issue trying to boot a Lenovo Legion 5 to Linux Mint 22.3. The Grub view loads up and gives me the usual options, but then trying to boot Linux Mint 22.3 I get:
error: attempt to read or write outside of disc ‘cd0’.
error: you need to load the kernel first.
Press any key to continue…
After some seconds I get returned to the Grub view.
Xperia 10 II, SFOS 5.0.0.73 Tampella, ISODrive 0.5.2.1. A very vanilla setup so if there’s some specific prerequisite I’m in all likeliness missing that.
If Sailjail is my issue here, what is the most correct way to disable it?
