Is Sailsync OwnCloud still working for you?
The SailfishOS integration is mainly implemented as buteo plugins, namely
  • buteo-sync-plugin-nextcloud-backup
  • buteo-sync-plugin-nextcloud-images
which I believe are Jolla proprietary (but once were briefly published under BSD license).
No idea whether these could be configured to do more than currently. Maybe they can!
Also I wouldn’t count on Jolla to (be able to) fix any breakage quickly should it appear, so an app relying on those wouldn’t be much better off than we are now.
Unsure/unknown, but I appreciate the thought/gesture.
However, at this point I’m looking to put my effort into something that follows upstream GNU/Linux more closely (probably the Furilabs FLX1 at the time of writing this).
Thanks again.
Yesterday needed old picture from my nextcloud sailsync-backup and noticed that my phone also did stop syncing them already in April. (heh, long time not to check the backups :shushing_face:)
First checked this @nephros way to fix that, but it seemed to work just like the original owncloudcmd version. So I did restore the original configs back to that.
Checked Nextcloud site about that client version from Which nextcloud desktop client version is working with which server version (server version newer than client version)?) - 💻 Desktop - Nextcloud community
As @nYK6zC said it is the Nextcloud 31 that defines that new minimum version and thus does not allow the connection. So if you have access to your Nextcloud servers configuration then the easiest way is to add the minimum allowed version definition to 2.5.2 there.
‘minimum.supported.desktop.version’ => ‘2.5.2’,
Sure this is not a correct solution either, but while waiting the Qt upgrade, there is no need to hack my otherwise working old sailsync app in the phone(s) at all. It works again and in the time of having a lunch I had again all my pictures up-to-date in the nextcloud server.
Can confirm your finding, excellent workaround though it is important to note that nextcloud has the following warning on setting a lower minimum desktop client version:
 * When changing this, note that older unsupported versions of the Nextcloud desktop
 * client may not function as expected, and could lead to permanent data loss for
 * clients or other unexpected results.
That explains “a lot” - i am using nextcloud from hetzner, no change for this option possible :confused:
Maybe i have to check different backup stragegies than manual one…
I have chosen to save my pictures via syncthing. On my local computer. Whenever I,m at home and my PC is running rhe camera folders are synced.
