How is Angelfish currently?
Working well too, here.
How to? Can you explain how to do that?
[quote=“Siltaar, post:77, topic:26464, full:true”] Hi, It’s here : [Dark theme | SailfishOS community wiki](https://sailfishos.wiki/books/apps/page/dark-theme) [/quote]
Is there any hope for libraries for XA2 too? For Angelfish 26.03.70 on armv7hl too….
I tried to use Angelfish, but my keyboard does not pop up when I want to type an address. What do I have to do?
You need to install the inputmethod maliit plugin.
Does anyone know how to accept certificates in angelfish?
What exactly is the problem? I’m not sure I understand the question, and the screenshot doesn’t help either.
It seems it does it automatically for cookies. When this message appears for me, it takes some seconds to disappear and the website finishes loading.
I can’t see “Accept” or “Decline” options if a webpage has a unverified certificate.
In my screeshot you can see a window in the bottom that say (well, it’s in spanish, but I’ve translated to english):
Would you like to continue?
If you wish, you can continue with an unverified certificate…
But “Accept” and “Decline” options are missing, so I can’t continue.
I have the same problem on some websites. I haven’t found a solution yet, sometimes reloading the page helps to get past this message
I see. It’s weird to phrase it as a question; it may well be that this is a UI problem, i.e. the buttons should be there.
If you depend on this site a lot you could look into adding the certificate(s) manually somewhere. Possibly globally - but some browsers seem to prefer their own collections.
Hi there all,
Cannot seem to find that specific package, is it gone?
qt-runner-qt6
Anyone could drop a copy somewhere perhaps?
Let me know,
Cheers,
O.
It’s in CHUM repositories. Not sure if there’s other ways but you should probably have Chum GUI up and running and install it from there.
Great tip, thanks – nope didn’t had that.. had to set this up from Storeman… for others:
[root@Fairphone5 defaultuser]# rpm -i https://openrepos.net/sites/default/files/packages/5928/harbour-storeman-installer-2.3.0-release10.noarch.rpm
Cheers & thanks
is Angelfish itself in Chum? Because I’m unable to find it
Look here: Packaging Qt6 (6.7.2) for Sailfish OS - #73 by mive
ah yeah, sorry I realized I phrased my question in a confusing way. I meant if install was available via Chum GUI as I can’t find it
wondered if it was a problem with my device or if it was intended
No, it’s the structure of the repos. The qt6 is experimenal and in piggz personal obs space. chum gui only shows what’s in chum.
Here the chum domain:
which does not overlap with :
@piggz any plans for the qt6 stuff getting into chum? I realize that there would be conflicts with qt5.15 packages?
Yes … changes are required to the scratchbox2 build environment to allow building qt6/kf6 in OBS, my understanding is these changes should get in the 5.1 release.
We dont really want to carry a custom build of sb2 on chum like i am currently doing in my home project.
