[Guide/Hack] Automatic Nextcloud file sync when directory contents change
Really? How? I spent 6 hours debugging this yesterday and it most certainly does not just work. Under some circumstances. Could you specify whether you had a ‘Personal’ calendar in your nc before setting up the phone? Are you using ‘Deck’ and or ‘Tasks’?
Testing another phone, account, now.
Using one of the calendars (the Personal that is default on nextcloud) from NC with a second account and other phone I have the same behaviour. None of my events from the phone’s default account get synced. But I’m debugging in another thread.
I dunno, it just works ™
https://i.imgur.com/OqujOlc.png
https://i.imgur.com/dEFpjP9.png
I havnt added to the calendar from the phone, i just add stuff in nextcloud web interface and see them appear on the phone. As you can see, it synced nextcloud contact birthdays, personal calendar and deck calendar
Ah, that’s what I meant. Stuff from the Phone Calendar and Contacts from the phone have to come from the nextcloud instance to sync. So, you’re in the same boat as I, I just made a false assumption. I’ve already synced contacts and calendars using vdirsync, so it looks like I need to ‘empty’ my phones and then sync. It’s a bit odd that sync on the phone won’t try to add the local calendars or contacts. Works fine from the phone with vdirsync.
thanks! :heart_eyes:
rclone works even on my old jolla-phone 1 with SF1.1.7.28 so now i syncing all devices
note:
recent nextcloud url is in format:
url = https://nextcloud.example.org/remote.php/dav/files/YOURUSERNAME/
