GPS Navigation that works
Same here. I need navigation, some guidance that gives me hints so I can have my eyes on busy roads and I need it for taking the right direction in a dense highway network.
MagicEarth always works fine on my old ipadmini cellular without a mobile connection and also on my Vollaphone without sim, offline.
On my XA2plus with Sailfish however not one satnav works. Location on, but no GPS. I tried MagicEarth and OSMand. I can download maps with MagicEarth, but my position is not located.
Is Here API (nice for routing and traffic) into Pure Maps also not working anymore?
I’m using it a lot and it works really good (at least until 1 or 2 weeks ago).
You just have to ask a Here API key.
try Google Maps / Komot, Android Support Crash after some Minutes using - #8 by St.Boom, this allows android apps to access gps freely as long it is turned on on XIII at least (with opengapps, but maybe microg hijacks them while pretending to be gms? worth a try)
Just did a quick test: Here WeGo(latest from Aurora store) seems to work with Android TTS installed.
It didn’t in the past(but back then the old one from Jolla store worked fine).
Installed it, seems interesting. German company.
Tried it again recently on my XA2 plus with the latest system update. No navigation with HereWeGo neither with MagicEarth. I get a route, that’s all. Both can’t find my location, while I can see a few satellites active in the GPS app. Tried it with different modes of GPS, but that doesn’t make any difference. I gave consent to MLS but I wonder if this still is functioning.
With the Jolla 1 Here worked fine. Since Jolla ported to Sony, maps and navigation always have been troublesome. That is why I still take two devices with me when I am driving: one phone with Sailfish and sim, the other an old iPad mini cellular or a Volla phone, both without sim, yet navigating reliable.
My Xperia 10 lll works with OSM Scout, Pure Maps crash. Android apps I haven’t tried. I use as much I can Sailfish apps.
Pure maps en latest HereWeGo(with Android text to speech installed) works fine on X10III. Used them a lot last few days.
Magic Earth doesn’t work, no GPS after a few seconds.
Are you sure you’re not experiencing the old XA2 hardware degradation issue? If you get a fix in decent time no navigation will work.
Sorry, I don’t know what you mean by ‘the degradation issue’. I updated the device to the latest release, but that can’t be the only reason it doesn’t work, because Here and MagicEarth never worked properly on the X, XA2 and XA2 plus. Always issues with GPS.
Some XA2 had hardware issues with GPS antennas.
I did move along a gpx track again this weekend on my motorcycle. OSM Scout was my choice for navigation.
Following the green line one the map is not bad but a real navigation alongside a gpx track would be much better.
I tried Puremaps, Here Wego and OSM Scout but afaik the can’t do that.
OSMand can navigate along a given gpx track but it’s Android and I find the interface confusing.
Do you know any native alternative?
Actually exept the accuracy on SFOS which probably comes from the gps fix problems and the quite low precision, navigation with Here works quite good. Okay i am using the navigation function without audio, and i am not that strict with the accuracy. :slight_smile:
Hi there all
I wanted to start using here as main nawigation in pure maps but I have some strange problem I think. My API works fine. I can find adresses and so, routing works, there is even info about the delay due to traffic but maps is not shown as can be seen here:
check that map tiles provider is selected that works. Note that MapTiler has limited number of tiles served per month and if you use API keys that are shared by all Pure Maps users you are expected to be in trouble towards the end of the month. Please use either free for use tiles or register your own keys
Im already using my own key. I had this situation before couldn’t get it to work so I tried again today. Problem is the same. What do you mean by map tiles? In pure maps menu in maps I have selected Here maps.
I took a short trip today and even streets names were displayed, so were signs of were the next exit from motorway would lead. But still no maps
HERE maps may have changed their API and that prevents loading them. Not 100% sure - haven’t looked into it
Could simple user like me do something about it?
Maybe it was already mentioned but I can really recommend Organic Maps.. You can get it in FDroid and also in Aurora. It uses OpenStreetMap and in a easier way to watch then classical OSM. Navigation in all Languages based on TTS. And of course also offline.
Well I do like CoMaps a lot. Get it from F-Droid. Could be an idea to port it to sailfish. Maybe ask them to do so. Interesting project.
I prefer it more than osmand.
Very good navi app. Works in waydroid op6.
