GPS in AppSupport works only once
I tried again yesterday, using ANWB onderweg, and of course it worked without issues now :slight_smile:
Although, after roughly 45 minutes of travel it started to hickup in updates, and about 3 minutes later it stopped completely. Tried again later that day and it worked again. What did change for me is that since the bug report I restarted my device (well more than once, but anyway) and I started having Stumblefish running in the background. Not sure if the latter makes a difference, but I’ll update the ticket with that information.
Being desperate, I tried Stumblefish but neverless the fix disappeared after roughly 20 sec and another one was aquired only after putting the app in the background and reactivating it.
I have not been able to reproduce the issue anymore :frowning:
Tried CoMaps a few times, no issues. But we’ll continue trying.
The issue is still present after updating to 5.1.0.18. I allowed everything for the app Enroute, but interestingly in MicroG Settings it is not show as App requiring location access. Probably this might be a hint?
I just noticed today that HereWeGo has some problems to get a correct position after start. Locations was kilometers away from my real position. A later restart with a parallel sfos app that uses gps worked better, nevertheless HereWeGo needed roundabout 15 second for the correct position while PureMaps and OSM Scout already had the correct coordinates…
For me the issue is gone after updating to 5.2.0.18. Tried HERE WeGo and CoMaps, both no issues. Well, there is of course the issue still that HERE WeGo needs pretty long before it gets a first location fix :frowning:
Yeah, no real problems with GPS apps since updating to 5.2.0.18 .
I spoke too soon. I tried two different Android GPS apps, and they both really struggled to get any GPS fix while I was moving, yet the native GPSInfo was perfectly happy :frowning:
Stopping & restarting AAS seems to have fixed my Android GPS problems - so that’s a work-around. If I work-out how to trigger the problem, then I’ll report it here.
For me it did not get really better. In OSMand I get and keep a location fix, but it doesn’t move with me nor does it correctly show my orientation.
In enroute I still get a location but it still doesn’t refresh or show my flight direction.
I think I have to wait for the next update, the changelog for microG mentioned things going on in GPS support.
Updated to 5.2.0.20, the GPS support in Appsupport didn’t improve. Still very long time to fix and no update when moving around in OSMand and enroute
I’m still facing this issue in 5.2.0.20 too. Confirmed on Waze: initially it gets the position, but then it keeps saying that “No GPS signal” while it’s turned on from Sailfish and native Pure Maps app is working properly.
Also, I can confirm that in 5.2.0.20, GPS works in Android navigation on the first app start. After closing and restarting after some time, I see the message “looking for GPS”. A full restart of AppSupport fixes it.
Same here. Restart of AppSupport fixes it for a while.
on 5.2.0.20
I had a look at MicroG Settings. Even if I open OSMand and it gets a fix it is not listed unter Settings/location, last apps using location.
