Those are per-site overrides, but I was referring to the default user agent. I found this that describes the recommendations:
About Windows/arm64:
About removing arch altogether:
In case someone missed it; the video is up:
I’ve got a bit behind with the discussion here, but thanks for all the comments.
You’re right, rebuilding just for JavaScript changes would be a real pain, but thankfully this bit, at least, can be streamlined. With JavaScript changes I transfer them directly over to the device (or sometimes even edit them on the device). Check out day 94 for a bit more on this.
Only that it’s on my to-do list. Once the WebView render is working, which I’m doing right now, it should be possible to install it without breaking the email client. So once I’m done with this I think it’d be worthwhile me spending some time to get a version others can really try out properly. I’ll post here when that’s available.
Thanks! I wasn’t sure whether to write about it, so glad to hear this. I’m not totally convinced this way was quicker than doing it by hand, but it was more fun
On the topic of user agents, I wasn’t aware of this aarch64/x86 hack Mozilla are using. That’s really interesting. It’s crazy that this stuff makes a difference, but given that it does, I personally think it’s worth following Mozilla’s lead. I’ll create an issue for it. Thanks for the discussion and links @direc85, @nephros.
I’m happy that the user agent string gets more thought, since it seems to be quite an important piece of the puzzle of getting more sites work properly… Hopefully with a good default user agent string the list of exceptions gets shorter too. And that’s where the community can really chip in!
Making a test release for the community is a nice idea indeed! I don’t remember if it’s just a JSON file on the disk or in a packaged file, but if the testers could change the content themselves, that would be even more helpful!
Thanks for making the avatar wall! I didn’t realize there are already so many contributors… It really is a community effort.
PS. The Rust 1.75 PR nudged forward a bit (compilation in OBS now works), we’re getting closer and closer of it getting merged.
@flypig came to mind, since theres mesa on sfos,
you can use thse env vars that might give more insight on the opengl side
Ive got some though questions that came to mind today while reading the latest entry of the diary.
It seems we are at the detail stage, where things seem to be ok but really are not, and when the size of the effort becomes clear (massive).
Now dont take this as an offence (not intended to be!); Is @flypig the only one working on the browser at the moment ? Noone at jolla picking up the ball? If thats the case, what is Jolla’s comment on this? Id assume the browser is a key component of SFOS product…and as such an upgrade would be due more support from jolla side, one d expect…
