By the way, if you didn’t see it already, Jolla released the .step-file for the original TOH model used for injection molding the stock TOHs. Now you can double check your dimensions against it and make changes if needed.
Fixed typo in topic!
Cool. I had no idea.
I checked it, while there are minor misalignments with the flashlight and camera module I think that falls within tolerances. Same goes for the clips.
Congratulations !!!
My new magnet ring arrived but it was too thick so I had to disassemble it a bit. Looks kind of nice with the individual magnets visible through the translucent PETG, though.
I also re-printed the camera cover part again, this time in PLA because I have a spool of PLA-Support-Filament that is super easy to remove and leaves a nice surface (and you can use ironing on the top surface - IME that doesn’t work well with PETG). I think that’s okay for the camera cover but I wouldn’t print the rest out of PLA either.
Have you considered uploading it to GitHub - sailfishos/toh-designs · GitHub?
If I understand correctly, it’s supposed to be(come) the place for both Jolla and Community ToH data.
I’ll have a look into it.
I have no experience with contributing to other repositories on git, always found that git is not really made for open hardware and clunky for it but Voron is also using Github so be it.
My question, what is the process to add ideally a new folder with the files needed for the TOH? Only Tomi Leppänen appears to have writing access.
I have no experience with CAD data and git, but STEP is basically just text so git should be able to handle it okay.
The usual process is to fork the repo, add whatever there is to add in the forked repo and then submit a pull request to the upstream repo.
Yours would be the first contribution and I’m quite sure Jolla have not thought about an exact process for this.
So we’ll have to see how it goes I guess.
Yes, uploading everything is not an issue. I am just totally new to the Github way of contributing anything.
I created the fork and subsequently a pull request. We’ll see where it goes.
cTOH-M has been merged on Github to the official Jolla TOH design repository. First non-Jolla entry ![]()
Congratulations are in order!
This TOH has the drawback that I can’t use it with the transparent protective cover. When leaving out the camera-protection part, there’s a gap that will let in dust.
The camera part would need to be redesigned for that, I guess. I don’t own a protective cover though, so I can’t test.
It would be enough if it came close to the original TOH.
I have a look at it.
You can try out this bump version. It is more fragile, maybe it has to be printed (without those supports but other supports) upside down.
Ah, great and thank you for the fast response, i will test it and post pictures here.
It works—thank you for your work! There may be one thing to correct, though: the TOH overlaps slightly at the top and bottom. Could this be the result of printing with a nozzle that’s too large? My coworker printed it for me. He said to remove it with a utility knife.
Support removed:
Overlapping:
The camera bumper fits well:
Overview:
Good camera protection:
Final:
Maybe I’ll apply a UV-printed image to it, like I did for our Jolla C2:
Nice. That bump turned out surprusingly well.
Did you print out the regular frame model or the one for “no sanding”? If it was the latter it might be that I did not remove the top/bottom margin completely. In the main file, the idea would be to sand down the margins, so there it is intentional.
