Claude (Code) on the Jolla
plausibly :sweat_smile: i am treating this jolla like a work horse tho to see whats possible - so it really has been through some stuff (especially in that measured timeframe) :grin:
the other way round is really nice. use the pc with sailfish sdk over ssh to let claude atonomously develop apps and test them directly on the device
thats what i also tried to do but i dont fully understand the infra of jolla yet - it does work tho. like how apps, uis, system integration, etc are built for jolla apps and such. i have seen Storeman, Chum, rpm downloads but i don’t know what the proper path is.
Do you mind sharing a link to a dev guide or info on your workflow? thanks!
if you know an app with a functinality you like to have you just tell claude, it gets the source code and finds the relevant code and adapts it. thats it
code > build > deploy > test > repeat
That’s the loop where the magic happens. You can go to bed and wake up hoping for a credit reset.
nice, youre also hitting the limits then
Do you believe you can create apps w/o any understanding what happened?
Claude is a tool. You can use this tool a a correct way to build nice things. But if you not mastering your tool the tool will play with you.
Maybe you love to be object of a game. But it is sure that Claude now own your data. So you are a Claude data object.
Not since I got my MCP just right :cook: :ok_hand:
So in my comment where I said i need to learn more about the system you critizise me for not knowing more about the system yet? I don’t understand.
Sorry, I was too general. For me is “running an app” not “learn more about the system”. And running an powerful app as root is (in nice words) is “gaming”. And running a well known data grabber as root is a very special kind auf “gaming”.
No. It is great to see you study the system. But that’s not my point. If you study for yourself typing commands and so that’s. When letting third parties on your system please study first the risks. Knowledge about a systems means always also knowledge about the risks.
absolutely valid. I did say in the original post that it is “not properly tested” and called it “yolo mode” exactly because of this. In later comments i said i am “treating this jolla like a work horse tho to see whats possible”.
You are absolutely right that if sensitive information was on the device this would be a dumb move. But considering it as an experimental dev device to me it probably is still dumb - but like one stage below the previous dumb :smiley:
And as i said, once i learned more about the system I can do much better than today anyways.
Presumably your Jolla account password is on this device.
This at least will enable Claude to fuck up the translations at translate.sailfishos.oxx.
Who knows, maybe it will order another 1000 phone licenses for you.
Please do share! Cooking up something myself and would be interested to see what you use. If I did miss a </s> sign there, though, ignore what I said :sweat_smile: :disguised_face:
If Anthropic paid for that, I’d call that redistribution of wealth in the correct direction, for once. :upside_down_face:
I would be surprised if claude, running without root, without my credit card info, with all its over-alignment and on an empty jolla device would be able to order 1000 phones unprompted.
Idk about translations and all but I could have worse things happen in my life than having to factory reset a phone while developing awesome (to me) apps and TOHs.
What @nephros is warning about is to be taken care of.
If things can be done with your Jolla ID+PW: better sign out before giving root access.
Out of that, the experiment seems a bit crazy and exciting.
Crafting-faffing-fiddling is also a way towards serious and square things, imho.
‘pkcon remove busybox-symlinks-xyz’ is rather safe as it will install gnu replacement automatically for most of the packages, not sure what the beef is between zsh and bash, but if you plan to use any scripts from the net gnu bash is the way (as is proper grep, sed, tar etc etc) as busybox versions are lacking basic and popular features, I think only two symlink packages refuse to be automaically replaced this way:
Available       busybox-symlinks-bash-1.36.1+git11-1.15.1.jolla.aarch64 (jolla) Busybox replacement for bash
Available       busybox-symlinks-bc-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)   Busybox replacement for bc
Available       busybox-symlinks-console-tools-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)        Busybox replacement for console tools
Available       busybox-symlinks-coreutils-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)    Busybox replacements for coreutils
Available       busybox-symlinks-cpio-1.36.1+git11-1.15.1.jolla.aarch64 (jolla) Busybox replacement for cpio
Installed       busybox-symlinks-dhcp-1.36.1+git11-1.15.1.jolla.aarch64 (installed)     Busybox dhcp utilities
Available       busybox-symlinks-diffutils-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)    Busybox replacements for diffutils
Installed       busybox-symlinks-dosfstools-1.36.1+git11-1.15.1.jolla.aarch64 (installed)       Busybox replacements for dosfstools
Available       busybox-symlinks-findutils-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)    Busybox replacements for findutils
Available       busybox-symlinks-grep-1.36.1+git11-1.15.1.jolla.aarch64 (jolla) Busybox replacement for grep
Available       busybox-symlinks-gzip-1.36.1+git11-1.15.1.jolla.aarch64 (jolla) Busybox replacement for gzip
Available       busybox-symlinks-i2c-tools-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)    Busybox replacement for i2c-tools
Available       busybox-symlinks-procps-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)       Busybox replacement for procps
Available       busybox-symlinks-psmisc-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)       Busybox replacement for psmisc
Available       busybox-symlinks-sed-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)  Busybox replacement for sed
Available       busybox-symlinks-tar-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)  Busybox replacement for tar
Available       busybox-symlinks-vi-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)   Busybox replacement for vi
Available       busybox-symlinks-which-1.36.1+git11-1.15.1.jolla.aarch64 (jolla)        Busybox replacement for which
There’s a gnu tools pattern that’s a bit safer to install
