yes, you are correct. I seem to have moved to submodules at some point. I will plead dementia.
I observed (for many years, i.e. many hundred CI-runs) that the time to download an image with its additional layers from DockerHub uses between 30% and 60% of the overall runtime of a CI-job at GitHub. Hence “Yes”, also publishing the coderus/github-sfos-build@XXXX and coderus/sailfishos-platform-sdk Docker images at GitHub would significantly speed up compile runs using these images. This does matter, because I let a CI-test run for each commit to a branch for which a PR to the master / main branch exists: Very often I end up waiting for the CI-test to finish before I merge such a PR.
GitHub provides a nice how-to / documentation on how to use GitHub’s Docker “registry”, including how to upload Docker images in an automated manner:
P.S.:
I dont like github actions ci, i like how gitlab ci works.
But almost all people primarily host and develop their software at GitHub, not at GitLab, or a Gitlab- or Forgejo- (e.g. Codeberg) -instance. Consequently your Docker images are by far most often and foremost used for CI-workflows at GitHub.
And, as you guessed, that does build. It does not create a release, but it does build. I was being hopeful that it would also produce a release ![]()
For the sake of completeness and to round off @coderus brief version above, this is a fully functional version that makes a github release and pushes the noarch rpm to that tagged release.
name: Github CI build
on:
push:
tags:
- 'v*'
pull_request:
branches:
- main
env:
RELEASE: 5.0.0.43
jobs:
build:
runs-on: ubuntu-latest
steps:
- uses: actions/checkout@v4
with:
submodules: true
- name: Prepare
run: mkdir output
- name: Build i486
uses: coderus/github-sfos-build@sfos5
with:
release: ${{ env.RELEASE }}
arch: i486
- name: Extract Version Name
uses: actions/github-script@v4
with:
result-encoding: string
script: |
return context.payload.ref.replace(/refs\/tags\//, '');
- name: Create a Release
uses: softprops/action-gh-release@v1
env:
GITHUB_TOKEN: ${{ secrets.GITHUB_TOKEN }}
with:
name: ${{ steps.extract_name.outputs.result }}
draft: false
prerelease: false
body: This release was autogenerated.
files: 'RPMS/*.rpm'
Many thanks to @coderus @olf and @nephros … I think I got the original ‘extract name foo’ from @Rikudou_Sennin
it’s -i486 suffix, not -486.
I do not comprehend why you set an ID, if you do not reference it anywhere?
I actually misguided @poetaster by telling him “If @coderus sets an ID here, it must be utilised somewhere [in GitHub workflow configuration YAML files or by GitHub actions], because that is an ID’s only purpose: Go find this place(s) to look for valid IDs defined by @coderus.”
