App ideas to develop for Sailfish OS
Sure, thanks.
I would do the same as @Rikles.
Perhaps more barcode scanning than adding data, in my case.
I remember we had an app called Autodisconnect, again on the N900 :smiling_face_with_three_hearts:.
IIRC, you could set a delay for mobile data, wifi, BT, etc, in order to deactivate them when they were unused.
I was using it a lot and it was great!
wouldnt it make more sense to support Maelstrom (thanks nephros for that stupid to type name c:) as it uses the magic wormhole protocol and can also share files inside the same local network (like localsend), but also via a 3rd party server for transfer outside of local network. And yes its fully E2E Encrypted.
Alternative spellings, all wrong and correct at the same time, documented in Issue #28.
Still easier than MHordekAI I guess.
eh, LocalSend and Magic Wormhole and Blip and AirDrop and PairDrop and whatever Google has are just ways to do the same thing. My family has Windows, various Linux, iOS, MacOS and and all sorts of Android devices, so LocalSend is just a very universal way to drop files between them as it supports a wide variety of platforms.
FlightRadar24 or alike for people who like air plains
there is free version https://www.flightradar24.com/add-coverage
apparently airlabs provides a key
there is also OpenSky as well
edit/update: well I tested if AI could make this one, and it made it easily a really good one. I might release it if people want it
@ahjolinna’s comment over here about the Muoto theming app having easy, terminal-free settings to set up the LPM screen, made me think it would be nice to have a graphical editor for mcetool in its entirety, similar to dconf-editor on desktop Linux.
thats not really a reason not to use magic wormhole or Pairdrop (i havent used the other - i know that apples thing works different though)…
Pairdrop is a website - so basically any system wih browser can use it
Magic wormhole protocol has many different apps and at least one for the mentioned platforms. i can recommend Warp for linux. I can understand that you want to stick to the known localsend though. Have also used it for everything before using magic wormhole apps and KDE connect. its just more convenient for me to also be able to send file to devices not in the same network (:
as discussed i released the first version of the app “Ferry Sync” now, please have a look and test it:
I would love a native Audiobookshelf client but the word “Audiobookshelf” hasn’t even been mentioned in the forum before, so maybe there’s not much interest in this. I’m not exactly the greatest developer of all time but if I have a long weekend and some motivation, I might take a stab at it. No promises, tough (especially in regards to quality :smiley: ).
Damnit just discovered https://www.inaturalist.org/.
Also, https://observation.org/
I guess the Plants app is going to get a brother eventually.
I have waaay too many unfinished projects.
love iNaturalist and I use it a lot on android, a native sfos client would make me extremely happy!
Okayyy. No pressure then :stuck_out_tongue: :smiley:
Alpha release of Offshore OpenFOODfacts client:
Please test and let me know what you think!
Ahahahahah yeah actually no pressure at all!
One good app is better than 2 mid ones in my opinion!
Maybe the situation could change once there are lots of devs to expand already existing apps, but personally right now it seems I’ll need quite some time to learn qt and start contributing
Great start! On the Jp2, scanning and finding the product just works ootb :+1:
Have you, by any chance, heard of BirdNET? :innocent:
sigh added to the list! :smiley: :smiley:
Though I’m not sure audio analysis is something I’ll sink my teeth into.
Now as I said, I really have way too many projects as it is, not saying I’ll do any of these additional apps, interesting as they may be.
I was thinking of maybe building a cotsworth calendar (it’s really the only one any sane society should ever use). But ended up just building a ics-file for this, to import as events to the calendar :smiley: >
A simple ics-file with the mods is an easy way do “modify” any calendar :slight_smile:
But, at the moment I’m building 4 apps:
Fiat Lux - Lightmeter app that can suggest settings on your camera for photography. (Having metering issues with the hardware on the Jolla Phone, might build a TOH)
Fiat Mos - Habit tracker, I wanna get a true picture of what I actually do, do I really read as much as I my self image says? Do I actually… ? I track weight, organ practise, languages, everytihing. The app is more or less done, will submit soon.
Fiat Vox - a simple chromatic tuner - I am a musician
Fiat Cor - a simple (for some reason getting the bpm to not slow down and go faster is strangely difficult) metronome. I usually use a physical one, but still.
I’ve asked Pleco to make a sailfish version for their app and offered to fix it for them. the android version is great, but native is always native.
Might do a Cotsworth/Eastman-first calendar app, would be fun.
Screenshots from the apps are below. I’ve chosen to create a ‘fiat colours’ alternative in each app, and another that just follows user ambience. It’s mostly cause I find beige/paper colour calming and cant find a way to get that with the ambience options in SFOS.
I’m building them mostly for me, and if anyone has use gor them - great!
