try using the -g parameter to download the gps file and see if that works
Thanks!
Using the above it tells me it is downloading. Then it logs out. To run the above command I have to cd into the huami-token folder.
The following must be run in the /home/defaultuser-folder: sh ./harbour-amazfish-script.sh 3 -g
Nothing more happens than if I just enter: sh ./harbour-amazfish-script.sh 3
Does it say if its building the GPS UIHH file like below?
[defaultuser@PhoneX23 ~]$ python3 ~/huami-token/huami_token.py -m amazfit -g -e -p
Getting access token with amazfit login method…
Token: [‘DQVBQDZOQmJaR0YyajYmWnJoBAgAAAAAAYT1EbURRM0xtMHhvcDMyUVZ5QVRvX2ZuZ0FBQVhrLVpTWUcmcj0xMCZ0PWh1YW1pJnRpPWFkYW1AcGlnZ3ouY28udWsmaD0xNzA5NTU4OTgzNjUzJmk9ODY0MDAwJnVzZXJuYW1lPWFkYW1Voh7UE9HN_COkrk8KbnRB’]
Logging in…
Logged in! User id: 7048326150
Downloading AGPS_ALM…
Downloading AGPSZIP…
Downloading LLE…
Downloading AGPS…
Building gps_uihh.bin
Logged out.
