Does this problem happen with the domain in DNS, or only with domains in the /etc/hosts file?
I have 2 subdomains with regular ports not in DNS, one I can use with http, the other not. Both are on the same domain, IP, webserver and the only change in httpd_vhost.conf is the name. Neither works with https. All failures have the same error as shown above. I used a new browser profile in /home/nemo/.local/share/org.sailfishos/browser, with the same results.
.spdns.de is a dyndns solution. so the url above is resolved by dns.
With native Jolla Browser and Ielig Web I can reach http://server.domain.local/ but not https://server.domain.local/, error messages as above. Host is defined in /etc/hosts. Firefox can reach both (host file mounted in container). Tested on 4.0 and 4.1.
Just tried on Firefox 110 and on Sailfish Browser on SFOS 4.5 and I get the same result. @gabs5807 are you still impacted by this bug?
I tested now out of curiosity using Firefox 110.0 @ Ubuntu22 and got 2 security warnings, accepted them and then I could see the page ‘Apache2 Debian Default Page … It works!’
edit: So maybe SFOS Browser blocks out of the same security reasons but doesn’t give an option to skip and proceed at own risk.
Click on > I understand the Risks and Visit site or Add permanent exception.
Tested the Mobydick page from post # 6 with Xperia 10 / 4.5.0.18 right now and after accepting the warning it works. Page is visible.
The Eierkopp page from post # 18 doesn’t warn but wants a username and a password.
The problem is solved on 4.4.0.72. Sorry for the delay after all the time
. So i close this bug report.
The automatic replacement from http://mobydick.spdns.de:4080/ to https://mobydick.spdns.de:4080/ is still there (it shows the message “Secure Connection Failed” …).
May be some changes are needed on the browsers about page to suppress the https enforcement
That’s your server that’s “faulty”. http://neverssl.com works as expected.
Why the server should be wrong when the URL works on firefox?
Your URL did not have :<port> extension
