Always good to be able to reply to yourself…
ssu re was set to 3.4.0. After manually setting it to 3.4.0.22 and refreshing, it is available now. Probably a side effect of my previous upgrade issues.
@vige it seems that maybe the ideal resolution of this issue is not allowing python3-sqlite but undoing the change made in 3.4.0.22 or making python3 depend on python3-sqlite (and any other python package that was separated) so that it is automatically installed.
Why do I say this?
OTOH - it could also be legitimate to allow stuff to break, but in that case there is really no excuse anymore to keep the harbour dependencies so limited.
https://gitlab.com/cy8aer/podqast/-/issues/26 I tried every possibilty but nothing worked for podqast.
See:
As far as I understand, when this version of pyotherside will be installed, the sqlite binding will be pulled automatically. I see this as a way to install automatically the bindings on SailfishOS.
But that has consequences anyways: sqlite3 is a standard library simply shipped with python. So Jolla removes standard libraries without any warning. And because it is a standard library it cannot be installed by pip . The certificate handling in matrix-nio (my bluepill library) depends on a working sqlite3 support. If there is no change or a working recipe from Jolla i must cancel any further development.It is complicated to hold everything together even if there is sqlite3 existing. Next week they change to python 3.9? Ok, then I need to redesign the thing and bring it out for this version up. How many versions should I support?
They tell us: “don’t use this, don’t use that” but then they are not consequent with their own library setup. If they tell: you can use standard python then they cannot cut standard python stuff out.
I must officially say: this system is dying for me.
Life will be better without smartphones!
My systems all depend to pyotherside. No automatically installation of sqlite. Try it out:
https://gitlab.com/cy8aer/podqast/-/jobs/778465598/artifacts/download?file_type=archive
And when will this patch be available? With SFOS 3.6 or 3.7? The actual SDK doesn’t have this patch. Try it out.
This will come with a version of pyotherside that is not in 3.4.0.22. But Jolla people created a dedicated branch in the project to support the 3.4.0 version, so I guess there will be a new release candidate one day:
One day? Where is their official statement. I am killing ressources for that. Bluepill needs about 30MB libraries (libolm) and python stuff (matrix-nio) which I need to pack into the app. I am not even sure that this will be accepted in harbour. Do they really think that they can ever support crazy good apps? Forget it.
@cy8aer This may help you for now:
Though it is not harbour compatible according to the SDK.
thanks for that. I’ll try it out. Is it harbour compatible?
Not according to the SDK, haven’t tried to upload to harbour yet, just added a note referring people to OpenRepos.
‘python3-sqlite’ added to 3.4.0.24
Can someone test podqast with 3.4.0.24 please? Without python3-sqlite the library does not work.
Hi
I tested with a fresh install device in .24 with only your repository enable
podQast run well
(add new url, play episode)
Just to clarify what happened: the python3-sqlite package is now a dependency for the pyotherside package. It’s not included in the images, but any app which uses pyotherside should pull it in. So it shouldn’t be necessary to make any modifications to the apps.
