Set environment variable for application
Hi.
I’d like to set an environment variable for the media player application.
I’m able to do that from the terminal with the following command:
env NEMO_RESOURCE_CLASS_OVERRIDE=event /usr/bin/sailjail -p jolla-mediaplayer.desktop /usr/bin/jolla-mediaplayer
but writing the exact same line in the Exec key of the .desktop file doesn’t work (the application behaves as if the environment variable was not set).
What am I missing?
Thanks.
I would guess that sailjail is discarding it. shouldn’t you pass it WITH sailjail:
–env=name=value
Not sure myself.
It seems that sailjail doesn’t forward unknown arguments to firejail, so I get the following error:
/usr/bin/sailjail: unrecognized option '--env=NEMO_RESOURCE_CLASS_OVERRIDE=event'
Hmm. I was taking a tip from firejail, but obviously it not necessarily 1 to 1.
Maybe it can be set in the .profile ?
https://man.archlinux.org/man/firejail-profile.5
But i frankly don’t know :slight_smile:
Thanks a lot! It worked!
I created a file /etc/sailjail/permissions/jolla-mediaplayer.profile with the following content:
Just a not that someone is using this profile file technique to set language for an app:
env LANG=de_DE.UTF8
