REPRODUCIBILITY: No Sound
OS VERSION: 4.5.0.24
HARDWARE: Xperia 10 II
UI LANGUAGE:German
REGRESSION:
On Android sound works on Sailfish not No phonecalls no musik , could not set a weather location
UI LANGUAGE:German
REGRESSION:
Please fill in the bug report properly.
What did you do? Doesn’t a reboot help?
And don’t add unrelated stuff that already has threads.
Sorry i am not so fit in english what did you mean a thread that exists ,
with the weather : reboot doasnt work with android it will no matter if location is on or off if i want too type my hometown it says : invalid authentication credentials
There is already a thread in this forum about the weather issue. You can use the search to find it.
please fill out the bug report form in your post with steps on how you tested if sound works and what you tried.
