Hello all. When trying to copy file to Phone it gives error 3 code permission denied Any ideias? Thanks
You should be a bit more detailed.
E.g. when does it give that error?
Are you sure about the error code as,
#define ESRCH 3 /* No such process */
says differently. Not a file operation, or?
Obviius things:
- Shut down alienDalvik?
- Got root (via devel-su)?
How do you copy over?
And we could continue…
write down what you did, compare to the guide and you may suddenly see!
AlienDalvik Off
Root
Devel-su
Copy directly to folder trough Mobaxterm and also with Winscp
Error 3 permission denied always showing
Hmmm.
What about copying to device /home/nemo and only then move to /opt/alien/?
Have thought about that and will try later. Thanks
