Hi. After long period I decided to develop application for SailfishOs, but something has changed. I did build the default template SDK application and build a rpm package for deployment. After manually installing package file and directory permissions are wrong and application fails to load.
qml directory and everything in qml directory are set to wrong permissions
SDK is the latest.
Last login: Fri Jun 6 22:28:44 2025
| Sailfish OS 4.6.0.15 (Sauna)
[nemo@Sailfish ~]$ ls -l /usr/share/harbour-test/
total 8
drwxr-x--- 4 root root 4096 Jun 7 11:45 qml
drwxr-xr-x 2 root root 4096 Jun 6 21:35 translations
[nemo@Sailfish ~]$ devel-su ls -l /usr/share/harbour-test/qml
Password:
total 12
drwxr-x--- 2 root root 4096 Jun 7 11:45 cover
-rw-r----- 1 root root 230 Jun 6 21:35 harbour-test.qml
drwxr-x--- 2 root root 4096 Jun 7 11:45 pages
[nemo@Sailfish ~]$ cat /etc/hw-release
# This file is copied as hw-release (analogous to os-release)
NAME="Intex Aqua Fish"
ID=l500d
MER_HA_DEVICE=l500d
MER_HA_VENDOR=qualcomm
VERSION="1.0.0.16"
VERSION_ID=1.0.0.16
PRETTY_NAME="Aqua Fish 1.0.0.16"
SAILFISH_BUILD=16
SAILFISH_FLAVOUR=release
HOME_URL="https://sailfishos.org/"
I’m working with the virtualbox SDK.When I create a new project using the wizard and then deploy w/o any changes this project to the phone it will work. But I have no experience with the docker SDK. Maybe a search for “docker” here in the forum will help.
At the left side of the SDK the is “project”. Here you can see all real settings behind the .spec. The wizard generated this.
Yep your SDK is building OK. A bit weird why is my SDK building packages with wrong permissions. Do you have latest SDK? Mine is latest and fresh install.
