Hi Guys.
I just bought a Xperia XA2 and a Sailfish X licence.
I have some troubles with WLAN, 80% of time, if i’m at more than 3 meter of my livebox,
Surfing is very slow, or doesn’t work at all. WLAN is connecter, signal seems good according to icon,
but very slow, or like disconnected.
Using the v16 vendor image like suggested in flashing instructions for 5ghz.
I tested the device on android, and it was working well, like all my other devices.
Have someone this trouble ? Or idea to investigate/ fix that ?
Thanks.
