OSVERSION: 5.0.0.72
HARDWARE: Xperia 10 III - xqbt52 - xqbt52 - 1.0.1.48 - aarch64
REGRESSION: not specified
Was looking for a workaround of [5.0.0.67][C2] Wireguard - Selected routed networks not set upon VPN activation and tried to add a User Route in the advanced Wireguard VPN settings.
To my dismay, the setup is not persisted.
I wonder If the routes can be added in the vpn settings file direcly - or if is not implemented at all.
A Wireguard VPN is defined.
- Create/import a Wireguard VPN
- Add and save a User Route in the Advanced settings
- Go back to main settings. Note: at this stage, going back to advanced settings finds the freshly added route.
- Save main VPN settings
- Reopen the VPN settings/advanced: the ‘User Route’ is gone
EXPECTED RESULTS:
User Route is persisted upon VPN settings save.
ACTUAL RESULTS:
Newly added User Route is lost upon VPN settings save.
- Patchmanager: no
- OpenRepos: yes
- Chum: yes
- Other: none specified
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.16+git2
