REPRODUCIBILITY (% or how often): always
BUILD ID = OS VERSION (Settings > About product): 4.0.1
HARDWARE (XA2, Xperia 10…): INOI R7
UI LANGUAGE: Russian
I have 3 SSID on same access point with different VLAN and passwords. Connect to one of this is successful. Then I tryed to connect to other SSID and get a “wrong password” error. Third SSID gave a same error. If I disconnect and delete first WLAN on device, then I can connect to any of two other, but only one. And after that connection to any 2 other will be failed. I try set a same passwords on all SSID, but no success.
WiFi access point with 3 SSID on same channel.
- Connect to one of SSID.
- Try to connect to other SSID on same access point and channel
Connect to other SSID
Get a wrong password error
