That is indeed the correct process, as far as I can tell!
Thank you both for your help! The issue is now resolved after the Group owner followed that process.
They reported back that the desktop client sent invitations even when they used the Add option; after adding me from the Android client it all worked okay (maybe thatās useful info for others as well).
āHow can I synchronize my phone book contacts similar to TG (Telegram) and WA (WhatsApp) with SG (Signal) , or is that still not possible and I have to enter each number individually?ā
Iām trying to register my first account and got HTTP 422 error and lots of library not found error messages. I have a fresh install of Sailfish on Xperia 10 iii (trial version) and Whisperfish 0.6.0.beta.21-0 from Storeman.
I got verification code after Captcha but after typing it Whisperfish just informs to close the application and send a bug report.
| Sailfish OS 4.5.0.24 (Struven ketju)
[defaultuser@Xperia10III ~]$ harbour-whisperfish
library "libutils.so" not found
library "libcutils.so" not found
library "libhardware.so" not found
library "android.hardware.graphics.mapper@2.0.so" not found
library "android.hardware.graphics.mapper@2.1.so" not found
library "android.hardware.graphics.mapper@3.0.so" not found
library "android.hardware.graphics.mapper@4.0.so" not found
library "libc++.so" not found
library "libhidlbase.so" not found
library "libgralloctypes.so" not found
library "android.hardware.graphics.common@1.2.so" not found
library "libion.so" not found
library "libz.so" not found
library "libhidlmemory.so" not found
library "android.hidl.memory@1.0.so" not found
library "vendor.qti.qspmhal@1.0.so" not found
2023-12-23 13:50:32.235 [WARN] src/sailfishapp.rs:211:int __cpp_closure_14317703314545309294_impl(QmlApplicationHolder* const&)(): Failed to load translator for ("en-US") Searched "/usr/share/harbour-whisperfish/translations" for "harbour-whisperfish"
2023-12-23 13:50:32.496 [WARN] "Failed to attach key memory region for qtcontacts-sqlite-np: QSharedMemory::attach (shmget): doesn't exist"
2023-12-23 13:50:32.496 [WARN] "Failed to open contacts transient store"
2023-12-23 13:50:32.496 [WARN] "Unable to open synchronous engine database connection"
2023-12-23 13:50:32.496 [WARN] QSqlQuery::prepare: database not open
2023-12-23 13:50:32.497 [WARN] "Failed to prepare distinct display label group selection query: \n SELECT DISTINCT DisplayLabelGroup FROM DisplayLabels ORDER BY DisplayLabelGroupSortOrder ASC"
[W] unknown:0 - "/home/defaultuser/.cache/be.rubdos/harbour-whisperfish/.mozilla/ua-update.json" parse error "illegal value" at offset 0
greHome from GRE_HOME:/usr/bin
libxul.so is not found, in /usr/bin/libxul.so
Created LOG for EmbedLiteTrace
[D] onUrlChanged:120 - Url changed to: https://signalcaptchas.org/registration/generate.html
Created LOG for EmbedPrefs
Created LOG for EmbedLiteLayerManager
=============== Preparing offscreen rendering context ===============
[D] onRecvAsyncMessage:128 - CaptchaDone Received!
[D] :108 - Captcha code sent!
2023-12-23 13:52:00.564 [ERROR] Error in registration: Unexpected response: HTTP 422
2023-12-23 13:58:06.239 [WARN] <Unknown File>: QML DBusAdaptor: Failed to unregister service be.rubdos.whisperfish
That would be 422 Unprocessable Content. I havenāt seen that before during regiatration, and generally that is one of the codes that should not happenā¦
I can be wrong, and I hope I am, but one possibility is that the registration API has changed. Iām away from my secondary SIM so I canāt immediately test this, and fixing that requires some actual effort anyway.
Meanwhile - could you set verbose: true (and perhaps logfile: true), try registration again, and send the logs privately to me? (But only try it once - it will not work, and itās not āpoliteā to repeat 422 requests.) You can find me at the Matrix channel, see the opening post for details!
Logs received, thanks @Alfh!
Unfortunately I was right ā the registration API has changed. Weāll have to update Whisperfish accordingly. Soā¦
PSA: Registering a new Whisperfish install is currently broken. Please do not attempt registration until the fixed version has been released (letās be polite towards Signal servers). Sorry for the inconvenience!
Sounds like PNI registration is mandatory now, which makes a lot of sense.
Whisperfish 0.6.0-beta.22
Several cool fixes and features.
Changes
- Fix a crash when downloading certain attachments
- Update from Rust 1.52 to Rust 1.75 to allow for many many many new cool things!
- Inline voice message player (highly overengineered!)
- Show identified delivery status in debug mode for group messages on per-recipient basis
- Fix a crash when messages are received on deleted group sessions
- Performance improvements on loading sessions and receiving read receipts
- Fix RUSTSEC-2020-0071 RUSTSEC-2021-0139 RUSTSEC-2021-0146 RUSTSEC-2021-0145 RUSTSEC-2021-0127 CVE-2023-42444 and CVE-2023-42447 (although unaffected by any of these)
- Update Emoji s to version 15
- Some initial work for receiving stories and distribution lists
- Fix deleting messages with attachments
- Decrypt attachments on a threadpool instead of on the executor (fixes lag/unresponsiveness on receiving attachments)
- Update libsqlite/sqlcipher to 3.41/4.5.0
- Rework logging subsystem for more concise and more useful logs
Currently, linking and registration is broken because Signal now mandates PNI/ACI support on clients. I will implement that next. There are several other cool new features upcoming too, stay tuned for a very soon update!
Really cool the list of changes!
Oh happy days! What a nice update! WF feels more and more robust app update after update. Youāve been hard at work.
Thank you for making voice messages work!
There might be a little bug though with playingā¦
One voice message conversation I made few weeks ago with Signal/Androidā¦there is only the last message of them playable and shows the voice frequency in message bubble. Other messages look like empty and are not playable dispite the play button.
When is coming recording+sending of voice messages?
Hmmmm, thatās interesting. Do you have logs, and can you elaborate on what device (Signal Android/iOS?) was used to send those messages?
Depending on how the weekend goes, might even be next week. But I have some other priorities to focus on first (PNI/ACI is a big one, username support soon, ā¦)
Sorry, have not had time to answer before now.
Those messages were send with Android version of Signal which is on the same phone I have WF also (Xperia 10 III SFOS 4.5.0.24)
I tried one time reproduce the anomaly, but it didnāt appear then.
I can try once more here some day how it works againā¦
I think what you see is a combination of two things: (1) attachments that donāt get downloaded completely; (2) voice messages that are received while the session is open donāt render until you reload the session.
Whisperfish 0.6.0-beta.23 āFOSDEM releaseā
Sever cool new features! I tagged this during the Sailfish OS dinner on FOSDEM-Saturday
(registration is still broken, but weāre working on the root cause!)
Changes
- Implement disappearing messages (a huge effort by @direc85 and myself)
- Implement message style rendering (mentions, bold/italics/ā¦)
- Implement receiving message edits
- Preparatory work for phonenumber privacy (PNP/PNI)
- Delete message notifications on remote message deletion
- Some other small clean ups that were long overdue
Important note about disappearing messages: Any existing chats will now expose and actually respect the expiry period (if such is set). The ādelete timerā for any old messages start when you open the chat with expiring messages and see the messages (again) ā this means that old messages and attachments are not deleted until you open the chat. The expiry period is saved per-message, so history is obeyed in that sense.
This behavior gives users opportunity to save the attachments out of the messages (open the attachment and select export from top pulley menu) before they are deleted with the message ā this is something Signal clients lets you do as well.
This is an important feature Whisperfish should have supported a long time ago, but all the puzzle pieces fell into place only now.
If youāre worried about losing data because of disappearing messages, making a backup of Whisperfish data folder is always a good, well, backup!
And as always, please report any issues and bugs you find!
Guys, you are incredible!
(this is a non-disappearing message
Just a quick update: Weāre preparing a small release to fix a few bugs and improve application performance. This will happen Soonā¢
This means now is the perfect time to translate Whisperfish using Weblate!
Whisperfish has had new translatable strings in most releases, the most recent notable addition being disappearing messages in beta.23 - that was 17 new strings if I remember correctly.
Help us get more languages completed! This is something only the community can make happen
Thanks!
Yes indeed. I just did Dutch, so I remember that too :ā-)
Just finished Greek
Did a bit of German.
Tried to do:
- Hƶfliches Sie ā Du-Form
- āGesprƤchā or āKonversationā ā Unterhaltung
- less passive forms
So please review also existing strings.
