WhatsApp won't verify the phone number
Good morning !
After getting my Jolla Phone 2026 last week and do some first setups, I ran into a problem and this topic here seems to be the best for it - before opening a Bug report, I wanted to re-try asking here…
My problem is exactly the same as the opening one from August 18:
I’d like to use WhatsApp on my Jolla as primary Phone. I installed the application - first from Aurora, then the .apk from WA Web page. Afterwards, I started the verification. I granted all permissions when asked; later in AAS Settings, I even granted every permission just to be sure. I wondered that for the .apk installation, granting SMS permission from the settings is not possible….
For the SMS, I get notified ‘The message could not be send to your number‘. My number is correct, without leading zero and with the country code. Then, the app crashes.
For the call verification: The requested call passes - the phone receives the call ! But Whatsapp won’t recognize anything from it.
So, no chance to verify - and no, I can not login with some google account here :wink: I did several restarts, too.
Android App Support is activated, MicroG set up (I’d prefer without, but WA is important for contacts and so just to try…). I don’t know what else to do or to configure. Even pairing with original WA on iPhone did not succeed.
To conclude:
It seems that the situation is still happening to others. Some users seem to have success, directly using WA or pairing it with their account on another device. Maybe I will give some workarounds such as WhatsUp a try in the future.
Are there some other advises I did not think of? Or is it a common problem that many users (still) face? Did anybody face the same problem and got a real solution for using WA on Sailfish OS only?
Maybe it’s only some issue in the pairing of Sailfish / AAS / microg compatibility ..?
I appreciate every help and reply and Thanks in advance. :slight_smile:
I just can say that in my case it eventually worked.. No idea why, did apparently the exact same thing 50 times and the 51 it worked. In my case I did recieve the SMS, and it was the way to verify it.
Has someone migrated WhatsApp successfully from iPhone to Jolla Phone 2026?
If Yes: Which Steps where performed in which Order? Was Chat history Migration from iPhone to Jolla Phone working?
I am also stuck on this issue. All of these verification options put the app it a hardlocked state that can only be recovered by deleting all its local data or reinstalling:
  • Missed Call
  • Receive SMS
  • Voice Call
If anyone knows how to get whatsapp going without requiring a second device (companion mode) i would love to hear it.
Not even talking about transferring data yet…
Sorry, I’m not familiar with iPhones. But transferring WhatsApp from Android is reliable and easy (~10min). I did it today with these steps:
  1. Create a local backup (WhatsApp Settings > Chats > Chat Backup > Backup)
  2. Force-quit WhatsApp through its app info screen
  3. Install ZArchiver from Aurora/Play Store
  4. Create a tar archive of Internal Storage/Android/media/com.whatsapp/WhatsApp/
  5. Send the tar archive to your new Jolla Phone e.g. by LocalSend ( Android / Sailfish OS )
  6. Install WhatsApp on the Jolla Phone and open it once
  7. Delete the contents of ~/android_storage/Android/media/com.whatsapp/WhatsApp/
  8. Install ZArchiver from Aurora Store and unpack the contents of the archived WhatsApp folder to the new one. You should end up with three subfolders “Backups”, “Databases”, “Media”
  9. Open WhatsApp and proceed with the setup. It will discover the local backup and restore everything.
Using ZArchiver avoids two issues:
  • file modification timestamps are preserved, so the media doesn’t show up in the Jolla Phone’s gallery as if they were all taken “today”
  • unpacking is done from inside AppSupport into a folder that WhatsApp created, this ensures correct file permissions
Compared to the complete transfer, you will need to re-link secondary devices and contacts see that your security code changed. But unlike the complete transfer, this method works with non-rooted Android phones.
This worked for me.
Installed WA from Aurora, call failed, but SMS verification worked, entering the code manually. Email verification likewise.
I have no old data to transfer.
Never liked WA, but need it for work, and in SFOS, it runs in a container.
I’m in the same place and I’m about to give up. If I can’t onbaord this horrific app, I can’t daily drive the 2026 model.
@sourcrowd worked for me as well.
as im coming from iOS there was no way around an Android phone.
My iOS Chat migration worked this way:
  • Migrated whatsapp chats from iOS to Android (fairphone 4), put cabel on and connected both phones
  • created there a local backup
  • then i started with migration guide from @sourcrowd above
