BUILD ID = OS VERSION (Settings > About product): 4.2.0.21 (Verla)
HARDWARE (XA2, X10, X10 II, …): XA2
UI LANGUAGE: German
I added a web calendar to my XA2. When creating events in the calendar via the calendar itself (Teamup webpage) this event is synchronized to my XA2. But when I change this event (e.g. move to another day or delete the event) the change is not synchronized to my XA2. This was working in the past. Not sure, if the bug is exisintg since the update to Sailfish 4.2
Web calendar added to Sailfish device. At least one event created. Change this event.
- Add a web calendar
- Create a event in the calendar
- Change this event in the calendar
Every change of a calendar event should be synchronized to my XA2.
Change of exising events (not new created events) are not synchronized any longer.
I read in the release notes for Sailfish 4.3 that there are improvments within the calendar application done by @dcaliste. Maybe these fixes are related to the issue I am reporting?
A workaround is to delete the web calendar and to add it again. But thats not how it should work.
