REPRODUCIBILITY: 100%
OS VERSION: 4.4.0.72
HARDWARE: geminipda x27
UI LANGUAGE: pl_PL
REGRESSION: cannot state, flashed the gemini first time.
Volume adjustment during the call on Gemini PDA is not working. The slider is switched to “call mode” and moves properly but it does not result in volume change. The same happens for earpiece and speaker modes.
- Start the call
- Use keyboard to change volume
- Observe no change in volume
Volume during the call follows the volume slider.
Volume during the call fixed at high level with no ability to change it.
Purely flashed system. Tried mulitple reflashes using android 7 and 8 as base with the same result.
