Voicecall UI not appearing when VoLTE is enabled & trying to call
REPRODUCIBILITY: 50%
OS VERSION: 4.4.0.72
HARDWARE: X10 II
UI LANGUAGE: Finnish
REGRESSION: -
I have now stumbled upon this bug a few times when trying to call someone using the Phone application and picking a number from the recent calls list. Basically the voicecall UI where the controls for dialing, muting, stopping the call etc. are not appearing at all and it happens only if VoLTE is enabled. I’ve tested couple of times taking the VoLTE off and there is no issue after that. The calls work normally though but no UI for call controls is displayed.
VoLTE enabled
  1. Make sure the VoLTE is enabled and registered
  2. Open Phone application
  3. Select from the recent calls list a person / number
  4. Make a call
Voicecall UI should appear with the controls for muting, dialing etc.
No voicecall UI appears and the Phone application displays the recent calls list. The call seems to work normally though.
No relevant modifications
Here’s Journal log, not sure if it helps. I am using Finnish operator Elisa.
Thanks for your report @Moppa5. I’ve created an internal issue for this and tagged it as tracked. If there are any updates on it to share, I’ll do my best to post them here.
X10II, 4.5.0.19: yep I see this happen often.
