View time & battery from within apps / not on home screen
Hi all, new C2 user here figuring out the UI on the phone after finally migrating away from the apple/android duopoly - does anyone know if there’s a way to view the time (and ideally battery %) when you’re inside an app? I struggle with time blindness and want to avoid losing track of time, but it’s hard to do so when I can’t see what time it is on my phone as is (or have to remember to go check the time on my home screen every few minutes).
I couldn’t see anything within my settings for time & date or display, is there something I’m missing or is this something that would be for a future update?
Thanks in advance!
Please peruse the search function before making a new thread:
… and probably one or two more.
Or go the trad way: swipe the open app from outside to minimize (or part of) so you can see the start screen and your missing time and battery values. And find out the easy way back to your running app. This wonderful design provide the largest possible app screen and a quick access to the clock.
Sorry! I had been searching but evidently wasn’t using the right search criteria. Thank you for pointing me in the right direction
I’d say it’s neither.
This has not been a feature of SFOS for the last decade, by design. (The design choice being to have the ‘peek’ gesture for this.)
Some people would like it regardless and hence the linked feature request, and patch were created.
My problem is that I’m often too ADHD to realise just how much time has passed before I remember to swipe back to the start screen :’) going to search through the threads posted above and see if there are any solutions there
Yes the search function here is great and always worth trying :100:
You don’t have to swipe the app away. Peeking means you swipe (and hold) from the sides until your app becomes transparent.
Glean what you want to know from Home Screen, then release and you’re back in your app.
I use timers, first tab, under Clock, I cut it a bit, but I hope you get the idea:
Which is cool, and with the app cover of Clock, you can ‘peek’ at time passed, or remaining.
