Videocalls and voicecalls via Threema (4.43) not working with Xperia XA2 [3.4.0.24] [WiFi]
REPRODUCIBILITY (100%):
BUILD ID = OS VERSION (3.4.0.24):
HARDWARE (XA2, and partly Xperia X):
UI LANGUAGE: German
Videocalls or just voicecalls via Threema (4.43) is not working with XA2 over WiFi. It is trying to connect but fails. I tried to call an Android device and also my Xperia X. It is ringing but the connection can not be established.
Making calls (over WiFi and mobile data) with Xperia X does work, but the frontcamera is somehow zoomed in and the picture ist streched. The backcamera is working fine. Calls are not stable though.
i remember, that it worked before the last update.
Edit 1 the test with XA 2 was done on WiFi.
Edit 2 I also tested over mobile data and it worked. So the issue is WiFi related!
  1. make a call via threema on XA2 over WiFi
should work
not working
Did you test WIFI and MobileData?
I tested via Wifi, I will test it with Mobile data this evening.
I can confirm this bug, using
Threema 4.43
Sailfish 3.4.0.24
Xperia XA2 Dual SIM
Videocalls and voicecalls does work with mobile data, but not via Wifi.
Threema Web does also not work via Wifi only with mobile data.
i can confirm this on xperia xa2 sailfish v 3.4.0.24.
Also jitsi meet and browser (sailfish browser and firefox) do not work with jitsi.
At this time, i cannot to video calls? Will this be fixed?
any Feedback here? is someone working on this issue?
