REPRODUCIBILITY: 100%
OS VERSION: 5.2.0.17
HARDWARE: Jolla Phone 2026
UI LANGUAGE: Polish
REGRESSION: no
After adding a new CalDAV calendar in the Accounts section, the events are seemingly synchronized very slowly in the Calendar app - despite them being seen in msyncd logs as new events.
Existing caldav calendar account to sync - mine is hosted by SabreDav, by an email provider Migadu.
Some (about 20 in one calendar, about 90 in second one) events to sync.
Add account in settings
Select two-way sync and 15 min sync interval
Force sync from pull down menu both in Account settings and in Calendar app.
All events should be visible in calendar app.
Only very few events are visible, more will appear after some time (few hours, even days, some are still not showing after 4 days)
None
I’m attaching the logs from few subsequent sync attemps - buteo sees quite a lot of new events to be imported from server, however it seems it doesn’t import them - as next sync attempts still show the same events left to import/update.
I have tried deleting the caldav account, clearing profiles in .local/share/system/privileged/Sync/caldav.ini, and removing the mkcal database in ~/.local/share/system/privileged/Calendar/mkcal/db - unfortunately it does not make any difference.
Logs with a domain replaced by “domain.redacted” (in a spoiler, I am unable to upload files yet):
\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[D\] unknown:0 - Synchronizer::getBackUpRestoreState\[D\] unknown:0 - Start sync requested for profile: “caldav-sync-8”\[D\] unknown:0 - Synchronizer::getBackUpRestoreState\[D\] unknown:0 - Starting sync with profile “caldav-sync-8”\[D\] unknown:0 - Disable sync on change: false false\[D\] unknown:0 - Starting out-of-process plugin “/usr/lib64/buteo-plugins-qt5/oopp/libcaldav-client.so” with plugin name “caldav” and profile name “caldav-sync-8”\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[I\] unknown:0 - Network status:\[I\] unknown:0 - Online:: true\[I\] unknown:0 - Connection:: 2\[D\] unknown:0 - attempting to register dbus service: “com.buteo.msyncd.plugin.caldav-sync-8”\[D\] unknown:0 - Plugin “caldav” with profile “caldav-sync-8” registered at dbus “com.buteo.msyncd.plugin.caldav-sync-8” and path /\[D\] unknown:0 - Process “/usr/libexec/buteo-oopp-runner” started with pid 8248\[D\] unknown:0 - Client plug-in runner initialized\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[I\] unknown:0 - Network status:\[I\] unknown:0 - Online:: true\[I\] unknown:0 - Connection:: 2\[D\] unknown:0 - sync-ui dbus interface is getting called\[D\] unknown:0 - Sync session started\[D\] unknown:0 - ClientPluginRunner started thread for plugin: “caldav-sync-8” , returning: true\[D\] unknown:0 - attempt to start sync session due to network session opened succeeded.\[D\] unknown:0 - Sync status changed for account “8”\[D\] unknown:0 - Sync running for 8\[D\] unknown:0 - Initiating config…\[D\] unknown:0 - Init done. Continuing with sync\[D\] unknown:0 - Authenticated!\[D\] unknown:0 - Already existing calendar: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/” “Wspólne” “#b1dd8b”\[D\] unknown:0 - Already existing calendar: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/” “Urodziny” “#fecb3e”\[D\] unknown:0 - found notebook: “daf003c7-d7b8-4872-bf04-34a35f9ea05a” for remote calendar: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/”\[D\] unknown:0 - void NotebookSyncAgent::startSync(const QDateTime&, const QDateTime&, bool, bool) “8”\[D\] unknown:0 - Start quick sync for notebook: “daf003c7-d7b8-4872-bf04-34a35f9ea05a” between QDateTime(2026-03-06 19:50:01.216 UTC Qt::TimeSpec(UTC)) to QDateTime(2027-09-06 19:50:01.216 UTC Qt::TimeSpec(UTC)) , sync changes since QDateTime(2026-09-06 19:49:35.000 UTC Qt::TimeSpec(UTC))\[D\] unknown:0 - void NotebookSyncAgent::fetchRemoteChanges() “8”\[D\] unknown:0 - found notebook: “d5487211-42e6-41f1-af3c-1d0948dc3064” for remote calendar: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/”\[D\] unknown:0 - void NotebookSyncAgent::startSync(const QDateTime&, const QDateTime&, bool, bool) “8”\[D\] unknown:0 - Start quick sync for notebook: “d5487211-42e6-41f1-af3c-1d0948dc3064” between QDateTime(2026-03-06 19:50:01.216 UTC Qt::TimeSpec(UTC)) to QDateTime(2027-09-06 19:50:01.216 UTC Qt::TimeSpec(UTC)) , sync changes since QDateTime(2026-09-06 19:49:35.000 UTC Qt::TimeSpec(UTC))\[D\] unknown:0 - void NotebookSyncAgent::fetchRemoteChanges() “8”\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - fetch etags finished with result: false “”\[D\] unknown:0 - Process tags for server path “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/A41E143C-502D-41D2-AA90-899FA4FF321E.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/cdbeacba-d557-4d6c-93ed-ca873535282b.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/f145f13b-7f49-4461-9c4d-113c2adbe249.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/C8F58391-F78D-48E3-87AE-C51CA1D13334.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/7D1400E1-12DF-4A5D-8242-D8EFD97C0513.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/c61ae867-938f-43c5-8cbb-496ff71d5e70.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/1E304053-B101-40AD-B34E-57FD2BE3F440.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/E39DFF4E-DAAF-4995-86BE-23BB48935DEF.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/429d9e2c-fe3c-448a-98c4-012b4fd77b05.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/FDAA0901-25D6-43C7-9DFE-797D9259CE33.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/3c9d6906-a210-4cdf-8a81-e9f2ce3a030f.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/ab97377b-541b-4713-a011-9b2cfb389994.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/5BDFEA40-2AB4-4518-A1BD-2C82D167C5BF.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/30A9E172-E47A-4A6D-BE50-AC08FBFF7D92.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/32c6a6b6-d043-4afd-9b0d-3ad0b326eb7d.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/81ddd45f-fcb2-4a45-b902-1d8fec02845a.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/1016e096-00a9-4c79-bf3a-cbdce90d0d8a.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/4c1918ab-1d48-478e-8f4a-276be96acf53.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/ECC2610F-8609-49D4-B354-0E6821AF3C4E.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/E242524E-8785-411E-B733-48922E575C65.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/6317ce71-59c4-4e9a-8b45-3b90f0e5e7bd.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/EE6BBA93-8960-4B75-B546-E7C25FB23FDF.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/4FDB8A45-D0E8-488B-BC7C-9028EF241CF2.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/77890275-8EAC-4397-8EEB-2944210C53F4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/2e1eb135-c55c-4cde-80fe-34079548fdc0.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/2D4CD83E-CDCC-4C95-B033-15AE7D7FD117.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/DDB257A9-0BC2-4A03-BB95-60522E5B78C1.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/8BD1AEAD-0432-491A-BFC3-D2D66A1B2BAE.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/b27030a6-f114-464e-a62b-afd1f695dc2f.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/97FF4E08-E051-4DF2-B2B6-107E6740B901.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/b156c3e9-2e82-449b-999d-aacf19a75081.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/8c531a6e-0732-444d-a9b0-b8c5fc8d31d4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/7E459695-99D2-48FE-8F72-EBC1EDE9A391.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/eed9cbc4-0fde-49a2-959f-de9015a83180.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/e25a137d-cbda-4481-9db8-99e93bcb9e0f.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/D491A807-E551-4C60-9F59-847658F41279.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/878299c5-ecb9-4416-af7d-5e313974069d.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/0AD8B945-75B3-4077-B4F9-DC8AC308AE75.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/83FA2A08-AF90-4B97-88B4-BF57A3036E2F.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/C259409E-DE5A-4A35-AA08-6C255AF344EC.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/D712C4FC-5326-43B2-97F3-1584DBACFFDA.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/F68145EA-4CAF-4A76-9883-E21CFC2A756D.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/F04BC19C-35BB-4797-9C49-C8155F5AE287.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/e758b17b-44bf-40db-acb8-a66e3cc6b7b4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/874475ec-d076-48fb-931b-77dc557d8662.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/358EEBF6-499B-4E6D-B53D-A1EFA9D682B5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/1B9EF331-D062-444B-A02E-939807E9097A.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/90390c4e-47b6-4c20-8d9b-6910df627fbc.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/0fde0e86-fd2a-49d0-b66b-63da3516d554.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/57951421-095B-4720-8403-067887867A99.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/63a671e1-ea37-47ac-9123-df79d1f34b17.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/96777289-eb65-4b3a-8bb4-209a8ce3f2bd.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/e0b2f4f0-7355-4d22-a912-e192e2ccc1a5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/9f916ba8-e8c5-4cdc-83c3-675d1941f16a.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/8DD7D9BD-0C97-4ADD-95B5-7A4C96130FF7.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/d7dc1e65-5177-4697-b362-45008b909c00.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/2E31F379-BE01-4CE0-A728-DB2B1646F2F3.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/45295FEF-084C-4E16-ADF2-73EE0B068BC9.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/35e1f948-babf-4de2-b60c-0ce9fdd48aea.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/3902211A-3A5C-4515-9397-46622F7AA777.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/61EE7748-0948-4018-9EF4-0F6A39782270.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/9E049F32-0745-47B0-BE7E-AF168759E149.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/57795aba-6ef3-4093-b464-c546da7ce85e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/eec8ba6b-9a59-4322-8dbe-37c5c903dff9.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/572dfee5-6f21-465b-9125-725b63fe9c14.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/955DC114-F826-4428-A088-49702045BBC8.ics”\[D\] unknown:0 - Calculated local A/M/R: 0 / 0 / 0\[D\] unknown:0 - Calculated remote A/M/R: 66 / 0 / 0\[D\] unknown:0 - void NotebookSyncAgent::sendLocalChanges() “8”\[D\] unknown:0 - no local changes to upsync - finished with notebook “Wspólne” “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/”\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - fetch etags finished with result: false “”\[D\] unknown:0 - Process tags for server path “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/fefd68cb-9a79-46ec-9a05-faf9e63b32ac.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/d2f06541-eb5b-4d9d-8057-1437f3f5c75e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/f2da18d9-1e4d-45c1-b312-0d3be50e65f9.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/85e99df6-55fa-425e-83ee-18d7245aeccf.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/bd1b99fd-9a11-44b8-9da8-4e24ce716f30.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/5de36331-4afa-4e37-93f1-8f221d4a105e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/7e0efd95-ccff-4c03-95c3-9d305c252ef5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/5af6b6a6-d7b5-45a7-ba76-c4b221fb9229.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/c0d15f88-3393-4cbb-a5c9-63ce49226783.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/6faaf494-7910-47bb-9fbd-d88b0795b1a5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/fd692f16-28be-41cf-8d1f-d1053ddc0a1e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/fd6582f0-6f55-48bd-898e-a3232cd74616.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/9e1b397f-9407-4af1-840a-1f0477a54195.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/c7dc32af-00ce-4101-8191-43d34c28eed4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/81ea3757-18ec-4496-9c91-2d83b61377b4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/10a0e99e-79e5-4321-99a5-a48fe09c735d.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/97d2f946-5e7d-4475-afb7-d93f62ebc9e7.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/4d7bbd6f-9994-4599-90dc-48550030eacb.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/faaaa2f5-5ef3-4228-9baa-47b73c7ffc92.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/3f19c16d-5261-4940-b129-4ead8d1c39cf.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/b2fe3a57-7a1e-40b5-914c-1847bb7ab8eb.ics”\[D\] unknown:0 - Calculated local A/M/R: 0 / 0 / 0\[D\] unknown:0 - Calculated remote A/M/R: 21 / 0 / 0\[D\] unknown:0 - void NotebookSyncAgent::sendLocalChanges() “8”\[D\] unknown:0 - no local changes to upsync - finished with notebook “Urodziny” “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/”\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - report request finished with result: false “”\[D\] unknown:0 - iCal data contains 1 incidences\[D\] unknown:0 - parsed 1 events or todos from the iCal data\[D\] unknown:0 - Report request finished: received: 1 iCal blobs\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[I\] unknown:0 - Notebook sync finished. Total agents: 2\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - report request finished with result: false “”\[D\] unknown:0 - iCal data contains 1 incidences\[D\] unknown:0 - parsed 1 events or todos from the iCal data\[D\] unknown:0 - Report request finished: received: 1 iCal blobs\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[I\] unknown:0 - Notebook sync finished. Total agents: 2\[D\] unknown:0 - bool NotebookSyncAgent::applyRemoteChanges() “8”\[D\] unknown:0 - bool NotebookSyncAgent::updateIncidences(const QList&) “8”\[D\] unknown:0 - Adding URI and ETAG to incidence: “3902211A-3A5C-4515-9397-46622F7AA777” “” : “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/ab97377b-541b-4713-a011-9b2cfb389994.ics” ““cb4fcf0f077786c33c19b72df1f2c261””\[D\] unknown:0 - Saving the added/updated base incidence before saving persistent exceptions: “3902211A-3A5C-4515-9397-46622F7AA777”\[D\] unknown:0 - Adding new incidence: “NBUID:daf003c7-d7b8-4872-bf04-34a35f9ea05a:3902211A-3A5C-4515-9397-46622F7AA777” “”\[D\] unknown:0 - bool NotebookSyncAgent::deleteIncidences(KCalendarCore::Incidence::List) “8”\[D\] unknown:0 - void NotebookSyncAgent::finalize() “8”\[D\] unknown:0 - bool NotebookSyncAgent::applyRemoteChanges() “8”\[D\] unknown:0 - bool NotebookSyncAgent::updateIncidences(const QList&) “8”\[D\] unknown:0 - Adding URI and ETAG to incidence: “b2fe3a57-7a1e-40b5-914c-1847bb7ab8eb” “” : “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/fefd68cb-9a79-46ec-9a05-faf9e63b32ac.ics” ““43bd5fb99efab645cfd8bcbcf84b9b0b””\[D\] unknown:0 - Saving the added/updated base incidence before saving persistent exceptions: “b2fe3a57-7a1e-40b5-914c-1847bb7ab8eb”\[D\] unknown:0 - Adding new incidence: “NBUID:d5487211-42e6-41f1-af3c-1d0948dc3064:b2fe3a57-7a1e-40b5-914c-1847bb7ab8eb” “”\[D\] unknown:0 - bool NotebookSyncAgent::deleteIncidences(KCalendarCore::Incidence::List) “8”\[D\] unknown:0 - void NotebookSyncAgent::finalize() “8”\[D\] unknown:0 - Calendar storage saved successfully after writing notebook changes!\[D\] unknown:0 - CalDAV sync succeeded! “”\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - virtual NotebookSyncAgent::\~NotebookSyncAgent() “8”\[D\] unknown:0 - virtual NotebookSyncAgent::\~NotebookSyncAgent() “8”\[D\] unknown:0 - Session finished: “caldav-sync-8” , status: 4\[I\] unknown:0 - ProfileManager::enableStorages\[I\] unknown:0 - ProfileManager::enableStorages\[D\] unknown:0 - Clean up session for profile “caldav-sync-8”\[D\] unknown:0 - Stopping the OOP process for “caldav”\[D\] unknown:0 - Process “/usr/libexec/buteo-oopp-runner” finished with exit code 15\[D\] unknown:0 - Sync status changed for account “8”\[D\] unknown:0 - lastSync: QDateTime(2026-09-06 21:49:59.000 CEST Qt::TimeSpec(LocalTime))\[D\] unknown:0 - lastSync: QDateTime( Qt::TimeSpec(LocalTime))\[D\] unknown:0 - aPrevSync “niedz. wrz 6 21:49:59 2026” Last Configured Time “niedz. wrz 6 21:49:19 2026” CurrentDateTime QDateTime(2026-09-06 21:50:03.956 CEST Qt::TimeSpec(LocalTime))\[D\] unknown:0 - Sync interval defined as 15\[D\] unknown:0 - numberOfInterval: 1 interval time 15\[D\] unknown:0 - next non rush hour sync is at:: QDateTime(2026-09-06 22:04:59.000 CEST Qt::TimeSpec(LocalTime))\[D\] unknown:0 - nextSync “niedz. wrz 6 22:04:59 2026”\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[D\] unknown:0 - Synchronizer::getBackUpRestoreState\[D\] unknown:0 - Start sync requested for profile: “caldav-sync-8”\[D\] unknown:0 - Synchronizer::getBackUpRestoreState\[D\] unknown:0 - Starting sync with profile “caldav-sync-8”\[D\] unknown:0 - Disable sync on change: false false\[D\] unknown:0 - Starting out-of-process plugin “/usr/lib64/buteo-plugins-qt5/oopp/libcaldav-client.so” with plugin name “caldav” and profile name “caldav-sync-8”\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[I\] unknown:0 - Network status:\[I\] unknown:0 - Online:: true\[I\] unknown:0 - Connection:: 2\[D\] unknown:0 - attempting to register dbus service: “com.buteo.msyncd.plugin.caldav-sync-8”\[D\] unknown:0 - Plugin “caldav” with profile “caldav-sync-8” registered at dbus “com.buteo.msyncd.plugin.caldav-sync-8” and path /\[D\] unknown:0 - Process “/usr/libexec/buteo-oopp-runner” started with pid 8276\[D\] unknown:0 - Client plug-in runner initialized\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[I\] unknown:0 - Network status:\[I\] unknown:0 - Online:: true\[I\] unknown:0 - Connection:: 2\[D\] unknown:0 - sync-ui dbus interface is getting called\[D\] unknown:0 - Sync session started\[D\] unknown:0 - ClientPluginRunner started thread for plugin: “caldav-sync-8” , returning: true\[D\] unknown:0 - attempt to start sync session due to network session opened succeeded.\[D\] unknown:0 - Sync status changed for account “8”\[D\] unknown:0 - Sync running for 8\[D\] unknown:0 - Initiating config…\[D\] unknown:0 - Init done. Continuing with sync\[D\] unknown:0 - Authenticated!\[D\] unknown:0 - Already existing calendar: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/” “Wspólne” “#b1dd8b”\[D\] unknown:0 - Already existing calendar: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/” “Urodziny” “#fecb3e”\[D\] unknown:0 - found notebook: “daf003c7-d7b8-4872-bf04-34a35f9ea05a” for remote calendar: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/”\[D\] unknown:0 - void NotebookSyncAgent::startSync(const QDateTime&, const QDateTime&, bool, bool) “8”\[D\] unknown:0 - Start quick sync for notebook: “daf003c7-d7b8-4872-bf04-34a35f9ea05a” between QDateTime(2026-03-06 19:50:20.737 UTC Qt::TimeSpec(UTC)) to QDateTime(2027-09-06 19:50:20.737 UTC Qt::TimeSpec(UTC)) , sync changes since QDateTime(2026-09-06 19:50:01.000 UTC Qt::TimeSpec(UTC))\[D\] unknown:0 - void NotebookSyncAgent::fetchRemoteChanges() “8”\[D\] unknown:0 - found notebook: “d5487211-42e6-41f1-af3c-1d0948dc3064” for remote calendar: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/”\[D\] unknown:0 - void NotebookSyncAgent::startSync(const QDateTime&, const QDateTime&, bool, bool) “8”\[D\] unknown:0 - Start quick sync for notebook: “d5487211-42e6-41f1-af3c-1d0948dc3064” between QDateTime(2026-03-06 19:50:20.737 UTC Qt::TimeSpec(UTC)) to QDateTime(2027-09-06 19:50:20.737 UTC Qt::TimeSpec(UTC)) , sync changes since QDateTime(2026-09-06 19:50:01.000 UTC Qt::TimeSpec(UTC))\[D\] unknown:0 - void NotebookSyncAgent::fetchRemoteChanges() “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - fetch etags finished with result: false “”\[D\] unknown:0 - Process tags for server path “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/d2f06541-eb5b-4d9d-8057-1437f3f5c75e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/f2da18d9-1e4d-45c1-b312-0d3be50e65f9.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/85e99df6-55fa-425e-83ee-18d7245aeccf.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/bd1b99fd-9a11-44b8-9da8-4e24ce716f30.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/7e0efd95-ccff-4c03-95c3-9d305c252ef5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/5af6b6a6-d7b5-45a7-ba76-c4b221fb9229.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/6faaf494-7910-47bb-9fbd-d88b0795b1a5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/5de36331-4afa-4e37-93f1-8f221d4a105e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/fd692f16-28be-41cf-8d1f-d1053ddc0a1e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/c0d15f88-3393-4cbb-a5c9-63ce49226783.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/9e1b397f-9407-4af1-840a-1f0477a54195.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/81ea3757-18ec-4496-9c91-2d83b61377b4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/4d7bbd6f-9994-4599-90dc-48550030eacb.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/97d2f946-5e7d-4475-afb7-d93f62ebc9e7.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/fd6582f0-6f55-48bd-898e-a3232cd74616.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/c7dc32af-00ce-4101-8191-43d34c28eed4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/3f19c16d-5261-4940-b129-4ead8d1c39cf.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/10a0e99e-79e5-4321-99a5-a48fe09c735d.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/b2fe3a57-7a1e-40b5-914c-1847bb7ab8eb.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/faaaa2f5-5ef3-4228-9baa-47b73c7ffc92.ics”\[D\] unknown:0 - Calculated local A/M/R: 0 / 0 / 0\[D\] unknown:0 - Calculated remote A/M/R: 20 / 0 / 0\[D\] unknown:0 - void NotebookSyncAgent::sendLocalChanges() “8”\[D\] unknown:0 - no local changes to upsync - finished with notebook “Urodziny” “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/”\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - fetch etags finished with result: false “”\[D\] unknown:0 - Process tags for server path “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/57951421-095B-4720-8403-067887867A99.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/63a671e1-ea37-47ac-9123-df79d1f34b17.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/96777289-eb65-4b3a-8bb4-209a8ce3f2bd.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/9E049F32-0745-47B0-BE7E-AF168759E149.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/9f916ba8-e8c5-4cdc-83c3-675d1941f16a.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/8DD7D9BD-0C97-4ADD-95B5-7A4C96130FF7.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/d7dc1e65-5177-4697-b362-45008b909c00.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/e0b2f4f0-7355-4d22-a912-e192e2ccc1a5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/2E31F379-BE01-4CE0-A728-DB2B1646F2F3.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/955DC114-F826-4428-A088-49702045BBC8.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/45295FEF-084C-4E16-ADF2-73EE0B068BC9.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/3902211A-3A5C-4515-9397-46622F7AA777.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/35e1f948-babf-4de2-b60c-0ce9fdd48aea.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/61EE7748-0948-4018-9EF4-0F6A39782270.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/57795aba-6ef3-4093-b464-c546da7ce85e.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/572dfee5-6f21-465b-9125-725b63fe9c14.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/eec8ba6b-9a59-4322-8dbe-37c5c903dff9.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/A41E143C-502D-41D2-AA90-899FA4FF321E.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/cdbeacba-d557-4d6c-93ed-ca873535282b.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/f145f13b-7f49-4461-9c4d-113c2adbe249.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/C8F58391-F78D-48E3-87AE-C51CA1D13334.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/7D1400E1-12DF-4A5D-8242-D8EFD97C0513.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/c61ae867-938f-43c5-8cbb-496ff71d5e70.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/1E304053-B101-40AD-B34E-57FD2BE3F440.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/5BDFEA40-2AB4-4518-A1BD-2C82D167C5BF.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/30A9E172-E47A-4A6D-BE50-AC08FBFF7D92.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/32c6a6b6-d043-4afd-9b0d-3ad0b326eb7d.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/E39DFF4E-DAAF-4995-86BE-23BB48935DEF.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/429d9e2c-fe3c-448a-98c4-012b4fd77b05.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/FDAA0901-25D6-43C7-9DFE-797D9259CE33.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/3c9d6906-a210-4cdf-8a81-e9f2ce3a030f.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/6317ce71-59c4-4e9a-8b45-3b90f0e5e7bd.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/77890275-8EAC-4397-8EEB-2944210C53F4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/81ddd45f-fcb2-4a45-b902-1d8fec02845a.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/1016e096-00a9-4c79-bf3a-cbdce90d0d8a.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/4c1918ab-1d48-478e-8f4a-276be96acf53.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/ECC2610F-8609-49D4-B354-0E6821AF3C4E.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/E242524E-8785-411E-B733-48922E575C65.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/EE6BBA93-8960-4B75-B546-E7C25FB23FDF.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/4FDB8A45-D0E8-488B-BC7C-9028EF241CF2.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/b27030a6-f114-464e-a62b-afd1f695dc2f.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/b156c3e9-2e82-449b-999d-aacf19a75081.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/8c531a6e-0732-444d-a9b0-b8c5fc8d31d4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/2e1eb135-c55c-4cde-80fe-34079548fdc0.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/2D4CD83E-CDCC-4C95-B033-15AE7D7FD117.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/DDB257A9-0BC2-4A03-BB95-60522E5B78C1.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/8BD1AEAD-0432-491A-BFC3-D2D66A1B2BAE.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/97FF4E08-E051-4DF2-B2B6-107E6740B901.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/83FA2A08-AF90-4B97-88B4-BF57A3036E2F.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/7E459695-99D2-48FE-8F72-EBC1EDE9A391.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/D712C4FC-5326-43B2-97F3-1584DBACFFDA.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/eed9cbc4-0fde-49a2-959f-de9015a83180.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/e25a137d-cbda-4481-9db8-99e93bcb9e0f.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/D491A807-E551-4C60-9F59-847658F41279.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/878299c5-ecb9-4416-af7d-5e313974069d.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/0AD8B945-75B3-4077-B4F9-DC8AC308AE75.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/C259409E-DE5A-4A35-AA08-6C255AF344EC.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/e758b17b-44bf-40db-acb8-a66e3cc6b7b4.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/F68145EA-4CAF-4A76-9883-E21CFC2A756D.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/F04BC19C-35BB-4797-9C49-C8155F5AE287.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/874475ec-d076-48fb-931b-77dc557d8662.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/358EEBF6-499B-4E6D-B53D-A1EFA9D682B5.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/1B9EF331-D062-444B-A02E-939807E9097A.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/90390c4e-47b6-4c20-8d9b-6910df627fbc.ics”\[D\] unknown:0 - have new remote addition: “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/0fde0e86-fd2a-49d0-b66b-63da3516d554.ics”\[D\] unknown:0 - Calculated local A/M/R: 0 / 0 / 0\[D\] unknown:0 - Calculated remote A/M/R: 65 / 0 / 0\[D\] unknown:0 - void NotebookSyncAgent::sendLocalChanges() “8”\[D\] unknown:0 - no local changes to upsync - finished with notebook “Wspólne” “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/”\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[D\] unknown:0 - void NotebookSyncAgent::processETags(const Buteo::Dav::Client::Reply&, const QHash<QString, QString>&) “8”\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - report request finished with result: false “”\[D\] unknown:0 - iCal data contains 1 incidences\[D\] unknown:0 - parsed 1 events or todos from the iCal data\[D\] unknown:0 - Report request finished: received: 1 iCal blobs\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[I\] unknown:0 - Notebook sync finished. Total agents: 2\[I\] unknown:0 - Current network state: true type: “WLAN” ( 2 )\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - report request finished with result: false “”\[D\] unknown:0 - iCal data contains 1 incidences\[D\] unknown:0 - parsed 1 events or todos from the iCal data\[D\] unknown:0 - Report request finished: received: 1 iCal blobs\[D\] unknown:0 - void NotebookSyncAgent::requestFinished() “8”\[I\] unknown:0 - Notebook sync finished. Total agents: 2\[D\] unknown:0 - bool NotebookSyncAgent::applyRemoteChanges() “8”\[D\] unknown:0 - bool NotebookSyncAgent::updateIncidences(const QList&) “8”\[D\] unknown:0 - Adding URI and ETAG to incidence: “2e1eb135-c55c-4cde-80fe-34079548fdc0” “” : “/calendars/wspolne@domain.redacted/aac648b9-44f8-4df4-9dd8-763258bce0a0/c61ae867-938f-43c5-8cbb-496ff71d5e70.ics” ““f50bd044268034718c81c8de23224c03””\[D\] unknown:0 - Saving the added/updated base incidence before saving persistent exceptions: “2e1eb135-c55c-4cde-80fe-34079548fdc0”\[D\] unknown:0 - Adding new incidence: “NBUID:daf003c7-d7b8-4872-bf04-34a35f9ea05a:2e1eb135-c55c-4cde-80fe-34079548fdc0” “”\[D\] unknown:0 - bool NotebookSyncAgent::deleteIncidences(KCalendarCore::Incidence::List) “8”\[D\] unknown:0 - void NotebookSyncAgent::finalize() “8”\[D\] unknown:0 - bool NotebookSyncAgent::applyRemoteChanges() “8”\[D\] unknown:0 - bool NotebookSyncAgent::updateIncidences(const QList&) “8”\[D\] unknown:0 - Adding URI and ETAG to incidence: “faaaa2f5-5ef3-4228-9baa-47b73c7ffc92” “” : “/calendars/wspolne@domain.redacted/eb8405ef-7057-4b45-81c9-3e5c7a7636f1/d2f06541-eb5b-4d9d-8057-1437f3f5c75e.ics” ““c3767edbe2745303ce86c4f21001a3a4””\[D\] unknown:0 - Saving the added/updated base incidence before saving persistent exceptions: “faaaa2f5-5ef3-4228-9baa-47b73c7ffc92”\[D\] unknown:0 - Adding new incidence: “NBUID:d5487211-42e6-41f1-af3c-1d0948dc3064:faaaa2f5-5ef3-4228-9baa-47b73c7ffc92” “”\[D\] unknown:0 - bool NotebookSyncAgent::deleteIncidences(KCalendarCore::Incidence::List) “8”\[D\] unknown:0 - void NotebookSyncAgent::finalize() “8”\[D\] unknown:0 - Calendar storage saved successfully after writing notebook changes!\[D\] unknown:0 - CalDAV sync succeeded! “”\[D\] unknown:0 - void NotebookSyncAgent::reportRequestFinished(const Buteo::Dav::Client::Reply&, const QListButeo::Dav::Resource&) “8”\[D\] unknown:0 - virtual NotebookSyncAgent::\~NotebookSyncAgent() “8”\[D\] unknown:0 - virtual NotebookSyncAgent::\~NotebookSyncAgent() “8”\[D\] unknown:0 - Session finished: “caldav-sync-8” , status: 4\[I\] unknown:0 - ProfileManager::enableStorages\[I\] unknown:0 - ProfileManager::enableStorages\[D\] unknown:0 - Clean up session for profile “caldav-sync-8”\[D\] unknown:0 - Stopping the OOP process for “caldav”\[D\] unknown:0 - Process “/usr/libexec/buteo-oopp-runner” finished with exit code 15\[D\] unknown:0 - Sync status changed for account “8”\[D\] unknown:0 - lastSync: QDateTime(2026-09-06 21:50:20.000 CEST Qt::TimeSpec(LocalTime))\[D\] unknown:0 - lastSync: QDateTime( Qt::TimeSpec(LocalTime))\[D\] unknown:0 - aPrevSync “niedz. wrz 6 21:50:20 2026” Last Configured Time “niedz. wrz 6 21:49:19 2026” CurrentDateTime QDateTime(2026-09-06 21:50:23.120 CEST Qt::TimeSpec(LocalTime))\[D\] unknown:0 - Sync interval defined as 15\[D\] unknown:0 - numberOfInterval: 1 interval time 15\[D\] unknown:0 - next non rush hour sync is at:: QDateTime(2026-09-06 22:05:20.000 CEST Qt::TimeSpec(LocalTime))\[D\] unknown:0 - nextSync “niedz. wrz 6 22:05:20 2026”
