REPRODUCIBILITY: On update
OS VERSION: Vanha Rauma 4.4.0.64
HARDWARE: xpERIA 10 ii
UI LANGUAGE:German
REGRESSION: Maybe
On first update to a (with fresh license) recently prepared phone with newly - via file transferred over bt - imported contacts, all contact info gone.
On second update, same result.
No patches / openrepo apps installed.
Have some contact numbers saved in your contact agenda, imported via file as well as added by hand.
===================ā
Upgrade.
Contacts should not be nuked
Contacts ground zero / All erased
If I remember correctly, I unpacked the backup-file from Xperia X on the laptop, copied the Contacts folder to the phone (Xperia 10 III), chose restore from āSettings - Apps - Contacts - Import from fileā and pointed it to the contacts file in the Contacts folder (I donāt remember what file format it was, but it worked). I did something similar with notes (phone call history I donāt care about, there will be new incoming calls).
