Downloading the picture and updating the ambience
First of all, I would start by creating a script that downloads the picture:
# Set this to the image on your server
url="https://example.org/image.jpg"
# The path where the image temporarily gets stored
tmp_path="/tmp/image.jpg"
# Download the image from $url to $tmp_path on your device (-L for following HTTP redirects)
curl -L $url -o $tmp_path
Next, tell the Ambience daemon to change the wallpaper over DBus:
dbus_response=$(busctl --user call com.jolla.ambienced /com/jolla/ambienced com.jolla.ambienced setAmbience s file://$tmp_path)
This will create a new ambiance. The $dbus_response
will now contain first a list of return types, in this case x
, followed by the values of the return types, in this case an integer containing the ID of the ambience created. You can use this later to remove or modify the ambience you’ve just created.
After this is done, save this script somewhere on your device and make it executable. I’m going to assume that it has been stored as /home/defaultuser/update-ambience.sh
for convenience.
Calling the script daily
Next, you will probably want to make this execute every day. This can be done using systemd. You’ll need to create a systemd service that will tell systemd on how to execute the script first. Create in ~/.config/systemd/user
with a name that ends in .service
, such as ~/.config/systemd/user/update-background.service
This file should contain the following:
[Unit]
Description=Change wallpaper
Requires=ambienced.service
After=ambienced.service
[Service]
Type=simple
ExecStart=/home/defaultuser/update-ambience.sh
For more documentation on this file, see systemd.service or man systemd.service
on a Linux distro that ships documentation.
After having created the systemd service file, a systemd timer service should be created. Give it the same name as your service file, but now use the .timer
extension instead of the .service
extension. I will use ~/.config/systemd/user/update-background.timer
[Unit]
Description=Update ambience daily
[Timer]
OnCalendar=daily
Persistent=true
[Install]
WantedBy=timers.target
This will run the update-ambience
systemd service every day on 00:00. If it has missed its target time, because the device was off at 00:00, the Persistent=true
will ensure it runs the next possible time.
For more information on timer service, see systemd.timer
Next, enable the timer by running systemctl enable --user update-ambience.timer
. If you used a different name, change the command accordingly.
FInally
This script isn’t ideal. It will create a new ambience every day and it does not remove the old ones. Removing the old ambiances is trivial* and left as an exercise for the reader
Additionally, I assumed the image will always be a JPG image. You might want to modify the script if it does not work for PNG images or whatever image format floats your boat.
Lastly, I haven’t tested every single step, so I’ve might made a mistake. If you run into any trouble, feel free to reply to this post.
*If you are fluent in bash that is, which I’m not sadly.
Useful resources to help you further:
DBus documentation
Since the ambience daemon is controlled over DBus, some DBus knowledge is helpful.
I think that reading this overview document up until the “Bus names” sections should give you a good overview of the terminology used within DBus: DBus Overview
As for a complete DBus documentation, please look at: dbus
DBus introspection of the com.jolla.ambienced
interface
This can be obtained by running busctl --user call com.jolla.ambienced /com/jolla/ambienced org.freedesktop.DBus.Introspectable introspect
on your device. This lists all the methods, signals and properties this interface supports.
<!DOCTYPE node PUBLIC "-//freedesktop//DTD D-BUS Object Introspection 1.0//EN"
"http://www.freedesktop.org/standards/dbus/1.0/introspect.dtd">
<node>
<interface name="com.jolla.ambienced">
<method name="indexFile">
<arg direction="in" type="s" name="url"/>
</method>
<method name="createAmbience">
<arg direction="out" type="x" name="contentId"/>
</method>
<method name="setAmbience">
</method>
<method name="remove">
<arg direction="in" type="i" name="contentType"/>
<arg direction="in" type="x" name="contentId"/>
</method>
<method name="reset">
</method>
<method name="installPackage">
<arg direction="in" type="s" name="path"/>
</method>
<method name="saveAttributes">
<arg direction="in" type="a{sv}" name="args"/>
<annotation value="QVariantMap" name="org.qtproject.QtDBus.QtTypeName.In2"/>
</method>
<method name="refreshAmbiences"/>
<method name="setFavorite">
<arg direction="in" type="b" name="value"/>
<arg direction="out" type="b" name="success"/>
</method>
<signal name="contentChanged">
<arg direction="out" type="i" name="type"/>
</signal>
</interface>
<interface name="org.freedesktop.DBus.Properties">
<method name="Get">
<arg name="interface_name" type="s" direction="in"/>
<arg name="property_name" type="s" direction="in"/>
<arg name="value" type="v" direction="out"/>
</method>
<method name="Set">
<arg name="value" type="v" direction="in"/>
</method>
<method name="GetAll">
<arg name="values" type="a{sv}" direction="out"/>
<annotation name="org.qtproject.QtDBus.QtTypeName.Out0" value="QVariantMap"/>
</method>
<signal name="PropertiesChanged">
<arg name="interface_name" type="s" direction="out"/>
<arg name="changed_properties" type="a{sv}" direction="out"/>
<annotation name="org.qtproject.QtDBus.QtTypeName.Out1" value="QVariantMap"/>
<arg name="invalidated_properties" type="as" direction="out"/>
</signal>
</interface>
<interface name="org.freedesktop.DBus.Introspectable">
<method name="Introspect">
<arg name="xml_data" type="s" direction="out"/>
</method>
</interface>
<interface name="org.freedesktop.DBus.Peer">
<method name="Ping"/>
<method name="GetMachineId">
<arg name="machine_uuid" type="s" direction="out"/>
</method>
</interface>
</node>
Additionally, to get an idea of how the system interacts with the ambience service, you can use busctl monitor com.jolla.ambienced
to see the method calls and signals over the bus. Try changing the ambience while you keep this command running and you should be able to see what happens.
