Hello, I’m having a few problems with the backup. I’m currently in the process of switching from my ‘old’ Xperia 10 III to the JP2026. The backup to the SD card stops with the error message ‘Could not load messages’. Backing up to Nextcloud works, but I can’t get the JP2026 to access the newly saved backup file; an old backup file in the same folder, on the other hand, is recognised. I’ve already found other solutions for contacts, accounts, calendars and photos, but text messages and, above all, the notes – which I absolutely need – haven’t worked yet. Following the instructions, which can also be found here Notes | Sailfish OS Documentation , it doesn’t work, because in the relevant folder .local/share/ there is no /com.jolla/ and no other trace of the notes either. Strangely enough, the Notes app works perfectly. But where does it store its data, and how do I get it into the app on the new JP2026? And if there were also any advice on how to do the same with text messages, in case the backup doesn’t work, I’d be grateful too!
How are you looking at this? With a jailed file browser or an actual terminal?
And /com.jolla/ is by definition not inside something - leading slash means filesystem root. Probably just a typo - but very important.
Oh, thank you! I didn’t expect the file browser not to display those files. This makes no sense to me. In the console I find them. I’ll try hopefully in the evening…
Just one more question: Is it possible, that I tranfer SMS-Messages I revieved on the old phone the same way? So just copy $HOME/.local/share/commhistory/commhistory.db in the corresponding place on the new phone?
No, there’s only a description to export SMS to Text, not to another phone. But I have just copied the files ($HOME/.local/share/commhistory/commhistory.db*) in the corresponding place on the new phone and after a restart the messages appear in the messages app. Thank you for your help!
