Top menu shortcuts order isn't persistent
OSVERSION: 5.2.0.17
HARDWARE: Jolla Phone (2026) - jp2601 - jp2601 - 1.0.0.17 - aarch64
UI LANGUAGE: Svenska (user: sv_SE, os: sv_SE.utf8)
REGRESSION: yes (since: 5.1.0.11 - aarch64)
Manually ordering top menu shortcuts doesn’t stay in chosen order.
1.Manually order your top menu shortcuts.
2.Reboot phone.
3. Go back to top menu and see your order is a mess.
EXPECTED RESULTS:
Shortcut order should be persistent.
ACTUAL RESULTS:
Shortcut order are not persistent.
ADDONS:
  • AAS Bluetooth Bridge: yes
  • Patchmanager: yes
  • OpenRepos: yes
  • Chum: yes
  • Other: none specified
Regression = X10III
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.18+git1
I have no idea what I did, but now it happens only after reboot. So I’ll edit initial bug report according to that.
