BUILD ID: 3.3.0.16
HARDWARE (Jolla1, Tablet, XA2,…): Sony Xperia X
UI LANGUAGE: EN
I have a newly flashed Sony Xperia 10 plus (dual-SIM) and have the same situation as described here
No of ideas in other topic helps.
I flashed 3 times.
Followed this instructions (can’t put a like because i am new user : -D )
Use Software binaries for AOSP Pie (Android 9.0) – Kernel 4.9 – Ganges (latest) v.9 form here
I tried to download and flash with vertions 8 and 7 but the ./flash script can’t find it and don’t flash the device. Output is SW … not found.
I have no ideas any more what can I try to get the WLAN works,
In Android WiFi Works, I had android 10 but downgraded it to Android 9 to install Sailfish like in howto
Flash Device
Start Phone
Enjoy (without WiFi)
WiFi should work
No WiFi Adapter found, No Mac Adress in the info view
I am having the exact same problem. I’ve also searched around and have been unable to find a solution. I feel a little cheated since I paid for the full version of SailfishX and I can’t get the wifi to work.
Mobile data works perfectly fine but I can’t afford to constantly use mobile data.
i had a sort of similar situation in my case imei was missing and later i lost wifi mac address too. have you tried going back to Android is wifi working?
same her. i reinstaled android a few times , and tested the wifi and it works, so in installed sailfish probably 6-7 times and then it works again . last time i downloaded sailfish x file from download link at jolla and reinstalled sailfish x from that file that did it for me , all is good now for me.
