hi can someone point me in the right direction to get a different keyboard for my sony experia 10 iii its just too small im struggling to type with it thank you …
Hello. I think you might be interested in looking at Storeman, they have some alternate keyboards. Though personally, as a Swipe-typer, I opted for OKBoard, which technically doesn’t open, but I found out you can just okboard-settings
it via the terminal and it works just fine.
Alternatively, there are also patches which you can look for using the Patch Manager (obtainable through Storeman as well, iirc)
thanks for that really appreciate your time it works a treat
