OSVERSION: 5.2.0.17
HARDWARE: Jolla Phone (2026) - jp2601 - jp2601 - 1.0.0.17 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: yes (since: n/a - n/a)
On boot up the system does not ask for the SIM pin if the sim pin is enabled in settings
1.Set sim pin in settings
2.Reboot the phone
3.
EXPECTED RESULTS:
Get prompted to enter the sim pin after unlocking the device the first time
ACTUAL RESULTS:
After unlocking the device it goes straight to the homescreen with enabled sim.
ADDONS:
- AAS Bluetooth Bridge: yes
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: none specified
Only one sim in slot 1.
I think this started with the update to 5.2.0.17.
Device Owner User: nemo
Home Encryption: enabled
