[Silica][Pickers] Folder Picker hangs in Landscape orientation
REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.62 (Tampella)
HARDWARE: Jolla C2 (s19mps / c2)
UI LANGUAGE: en_GB
REGRESSION: unknown
When selecting a directory using a Sailfish.Picker component, the UI hangs if the device is in Landscape orientation.
unknown
  1. Open QML app (see below) in Portrait orientation
  2. Click the button (or open a FolderPickerDialog in another way)
  3. Navigate to a dir with subdirs
  4. Navigate to a dir → see contents shown
  5. Navigate back
  6. Turn device into Landscape orientation
  7. Navigate to a dir → Empty page opens (in Portrait orientation), showing a spinner that never finishes
  8. If you have time, navigate back, rotate into Portrait again, go back to step 4
Functionality should be the same despite any device orientation
Hanging UI
  • Chum
  • OpenRepos
  • Patchmanager
  • Tinkering
QML app showing the issue:
import QtQuick 2.6
import Sailfish.Silica 1.0
import Sailfish.Pickers 1.0
ApplicationWindow { id: app
    allowedOrientations: Orientation.All
    initialPage: Page {
        SilicaFlickable {
            anchors.fill: parent
            PageHeader { title: "Demo" }
            Button {
                anchors.centerIn: parent
                text: "Click Me"
                onClicked: pageStack.push(picker)
    Component { id: picker
        FolderPickerDialog  {
Copy into a file, run with qmlscene demo.qml.
the initial version of this bug report was not created using any version of Bugger!.
To any users reading this, could you try running the code and confirm that you can reproduce?
Thanks.
What you should do approximately is:
Open a terminal, and have the code above in the clipboard (this is easiest by using a ssh connection):
devel-su pkcon install qt5-qtdeclarative-qmlscene
cat > /tmp/demo.qml
# << now paste the clipboard >>
# press ctrl-d
qmlscene  /tmp/demo.qml
Confirmed! I can reproduce on my X10III.
