Are there any Shimano eTube users here—any cyclists?
I have a problem:I managed to download it,but I can’t get the app to start. v.5.4.6,
I need to connect to my bike so I can adjust it using my phone.
That’s on my to do list, but haven’t yet tried as I have an old Android phone for those stuff. I’ll let you know if get it to work.
Well, with Sailfish 5.2.0.18 no luck: E-tube won’t open. I tried only the latest version though.
To be honest e-tube is barely working on android. For big updates, I had to optimise the distance of the phone to the bike to keep a steady Bluetooth connection (~1m something).
Eplus seems to boot but my ep8 is not hacked, so can’t test.
what do you mean is not hacked?
Eplus is not the official app, it’s an aftermarket software for modified motor softwares. The main goal is to increase the motor’s speed limit over the legal value (above 25km in europe). It is legal as long as you stay on private roads, but no bike can be sold with that hack.
Thanks for explanation! So Eplus is a similar app as e-tube that allows you to remove the speed limit? Shit… I have to try it myself. Thanks man!
Hi,
Where we can download that eplus?
Best would be to check their website since there is more than installing the apk. You need to flash the firmware of the motor first, using the appropriate connection cable and a computer. https://www.eplus.bike
I did it using the eMax app. Since then, I’ve been able to freely adjust my bike’s assist levels and speed using Shimano E-Tube. With my android phone,before i got jolla.
I guess the best option is to keep an old android phone around for the few apps that won’t work.
I will check on eMax, maybe a better option. Did you run your drive at 35km/h? Any issues with overheating or battering running too fast?
I have ep6 gen2, it becomes practically unlimited when it is changed to 45/km/h, the gears are not enough to go faster. I have changed ep6/ep8, without problems, the bikes have been driven approx. 3500km,offcourse,track…
and speedometer shows right with emax tuning.
I’ll need to check,does jolla connect to bike,if,i can use emax app ![]()
eMax can’t find the bike when running in SailfishOS AAS. I also tried it on my LineageOS phone, but the app crashes there. No luck so far, Sailfish may not be at fault here.
Yeah, jolla Bluetooth found the bike, but the app won’t connect. The eMax app connects fine on my Android.
