Selfhosted carddav and caldav for SFOS
I look for a light xDAV server known to work well with SFOS CardDAV and CalDAV, family usage, nothing fancy.
In no particular order, one of Baïkal, DaviCAL or Radicale - maybe other - will run on a Pi5 for the task.
Which of them is known to work well with SFOS ?
What are the known limitations?
I hope to avoid duplicate calendars and god knows what other issues I saw
I’ve been using Radicale for many years and just put the accounts into my new Jolla phone. Works like a charm!
But I would think about something like Nextcloud that includes this and much more in one piece. The only reason I’m not running it is that I have been running separate services for longer than Nextcloud exists.
I use Baikal for Calendar and Contacts and installed it on my webpresence, works very good with Sailfish OS.
Yeah, nextcloud would also my way to go. Iirc there is something like nextcloudpi which is running nice on this device. Card and cal dav work very well with sfos and no problems so far at least for me
I also use Baikal, it just works
Does not qualify as light (although you can disable certain components), and it’s a mailserver+groupware solution, but Mailcow has been working flawlessly for me for almost 10 years.
Containerized, a breeze to upgrade, great webgui and uses standard components under the hood.
Calendar and email support works very reliably on Sailfish with Mailcow from my personal experience, and i had to do zero fiddling: it picked up all calendars and contacts on first discovery.
I use NextCloud (which works well), but it’s about as far from lightweight as you can get.
Tried baikal 1st - j2, v5.2.0.22.
I exported the SFOS calendar and contacts.
First I tried to import the vcf into the ‘baikal’ collection with vcardconvertot - it took its time for +400 contacts but did nothing - no error nor Baikal contacts.
Then loaded the ics and vcf to thunderbird and synced to baikal. That went well up to baikal.
Contacts: i had to remove/recreate the Card Dav and CalDav account on SFOS for baikal contacts to appear in People app.
Calendar - no event imported from Baikal, nothing.
Managed to upload one from SFOS, then renamed. Rename does not go up to baikal.
Uploaded an event from Thunderbird (it reaches Baikal).
Nothing comes down to SFOS.
Is it the xxxDAV implementation or SFOS or its Baikal ?
