BUILD ID: ??
HARDWARE (Jolla1, Tablet, XA2,…): XA2
UI LANGUAGE: Any
Selecting or opening an image in a Jabber client will take you to the image gallery.
This should not happen.
None
A
- Download a Jabber client (Atalk/Conversations).
- Send a file/image.
- Select an image.
B
- Send a file/image to the client.
- Open sent image.
A) Image will be sent.
B) Image will be shown fullscreen
A&B
You are thrown into the gallery section and there’s no way out.
And from then on, when you enter your Jabber client, it opens the Gallery.
I can’t tell if this issue lies with Sailfish or with Conversations and Atalk.
