REPRODUCIBILITY: yes
OS VERSION: 5.0.0.72
HARDWARE: xperia 10ii
UI LANGUAGE: n/a
REGRESSION: unknown
arp_filter is not enabled on the network interfaces of the phone, this causes network information to be leaked between networks the phone is connected to.
None
Let your phone be connected to wifi and cellular at the same time
Inspect the ARP tables of the firewall/router and you will find many entries from the phone related to the cellular network.
I should not see the (CGNAT) cellular data IP addresses of my phone in my routers ARP table.
Already described
/proc/sys/net/ipv4/conf/*/arp_filter
Should probably all be set to 1.
