Hi
I have a Jolla 1 and want to update to 3.4 but my experience updating Xperia X is not good, what i need to do?
Uninstal Storeman and aliendalvik and after update install both again?.. How to uninstall aliendalvik?
Thx.
Hi
Thx.
I had 0 troubles with my JollaPhone (had massive issues with Xperia 10). I didn’t any of the known offending applications/patches installed on the JollaPhone, but I had both Storeman and AlienDalvik on it. You can always install app called sfos-upgrade from Storeman if you don’t trust the GUI method.
Hi there, I have never had any issues with updating the J1 via GUI. I don’t use patches and always carefully read the release notes. For what it’s worth, here is my “checklist” for updating:
Make a Backup to SD-card
Delete unnecessary files, etc. to maximize space (I have at least 5GB open)
Enable Developer Mode, Remote access and enter a password
In terminal, as devel-su: btrfs-balancer balance
For openrepos/Storeman: In terminal, as nemo: for i in $(ssu lr 2>&1 | grep openre | cut -d" " -f3); do ssu dr $i ; done
(This will disable all openrepos repositories. Don’t worry about the warning messages.)
Uninstall all problem-causing apps as per release notes (I uninstalled Storeman before 3.4 update, just in case)
Switch the phone off and back on. Stop Android support.
Under Settings, SailfishOS Updates: Select “Check for Updates” from the pulley menu again. When ready, select “Download” from the pulley menu. When ready select “Update” from the pulley menu.
Once update is complete and phone is finished booting, open terminal and as nemo run for i in $(ssu lr 2>&1 | grep openre | cut -d" " -f3); do ssu er $i ; done to enable openrepos repositories again.
In terminal, as devel-su: pkcon refresh
In terminal, as devel-su: zypper refresh
Thank you for the help… ill try it in this way.
