Sa0114adb.inf does not work on win11
REPRODUCIBILITY:
OS VERSION:
HARDWARE:
UI LANGUAGE:
REGRESSION:
DESCRIPTION: sa0114adb.inf does not install correctly on win11. I am trying to flash SFOS to xperia XQ-DC54. It is possible to install the .inf to win11 but it is connected to 0 devices.
I have no specific knowledge of Win11, but there are well-documented challenges with USB ports. You may need to install fastboot drivers for Windos, you may have to use a USB2 port.
Please check SailfishOS installation documentation, olf’s guide and search the forum for detailed advice.
as @jojomen suggested, there is a guide from @olf that helps you minimize problematic conditions that could lead to SFOS installation failure.
Try olf (Olf0) / Installing Sailfish OS · GitLab
