Reviving CepiPerez's FlowPlayer
It probably cares very little about directories, but about metadata. Can wav even have that?
Description says it supports wav, you can try to rename a couple of files from wav to flac, if it at the end uses some qt libraries to play the media those usually do independently of extension format detection (works for webp files renamed as jpg or vice versa), so might work? Worth a try, if not, tough luck and someone will need to dig into cpp files to add wavs as supported for albums
I was not aware about metadata inside sound file. Indeed the program cannot find (or there are no) metadata with my .wav files.
I start putting them in via the program for all the tracks of an album and Flowplayer then recognize it as an album. So a good point.
I am however not sure if the meta are then stored in the track or only saved in the database.
In this process it could be nice to pre- fill in the fields of the formular according to the name of the track rather than with the words artist and album . The title is captured automatically by the program, which is nice. But tracks name or m3u files if present often (always ?) contains Artist - album - trackname. It would be nice to only have to confirm the metadata rather than repeatedly typing them in . Or alternatively to select a collection of tracks inside the unknown album to set the fields artist and album.
If i find time i will have a look at the code.
DeedBeefSilica might be an alternative music player that can operate folder and file based and is not easily confused by tags or meta informations.
My ~ 100 GB collection of audio files also misses proper file tags. This why I do not use Flow Player
@olf, I am no developer and even more so this project looks quite complex as a starting point for a newbie… nevertheless, I’d like to give it a try and play with the code and the Sailfish SDK locally.
I managed to compile it for the emulator. During install on the emulator, installation fails due to certain dependencies missing (com.jolla.mediaplayer).
Do I understand correctly that this project can only be developed on a real device set as an SDK target?
Thanks
A followup to my previous message.
I’ve been experimenting a bit with Deepseek as of lately and I’m testing the results on flowplayer’s code.
Very slowly, step by step, I’ve been iteratively fixing some little bugs. I created tags and branches to avoid gigantic commits. Still LLM but not on full autopilot.
So far:
  • multi cd support seems to work
  • batch album cover download works
  • prefer embedded covers
  • lyrics fetching + synced to playback highlight
  • Bluetooth start/stop (crude implementation based on audio sink status change)
The changes are applied on my own forked repo, as I don’t feel comfortable with the LLM aspects and want to respect what has been done by all of you.
I’m comfortable enough to share the code, though :grinning_face_with_smiling_eyes:
This, in case anyone wants to try the player, help debugging or just wants to see what Deepseek did, cherry pick, and merge it into the main repo.
I am happy to accept a “take your vibecoding with you and go away”. I totally understand. I’m just not learning c++ and qml fast enough, for how hard i try. Sorry.
As i mentioned in the Repo README this is a personal experiment. I picked up the task since I don’t want this player to be abandoned. It has potential :grinning_face_with_smiling_eyes:
If interested drop a message and I’ll share the repo. At the moment i have no github pipeline to generate the rpms, i compile locally with the SDK.
All right, I’ve been trying Claude and there are some features that came out nicely. This stuff is scary.
I expanded the README to clarify the use of LLMs, what’s the point of my experiments and which features have been added.
New screenshots have been added too so you get an idea.
Main changes:
  • sort by track number by default
  • Improved Multi-cd support
  • Revised home with new icons + queue and favorites buttons for easy reach
  • Resume from last state (playback progress and active page)
  • Omnisearch
  • “Genre” support
  • advanced queue editing (multiselect, drag, send to end/send to start of queue, play next)
  • better webradio support
  • better lyrics support
I’d be really happy to hear your thoughts in general, to collaborate and to iron out any bugs. I’m particularly interested in how it performs with big, non-structured collections.
:warning: Please check the whole README since it includes important notes
, especially the coexistence with FlowPlayer
Take a backup of the existing flowplayer config (specified in readme), since I’m using the same app name + config path and I have not implemented any advanced DB migration logic.
(not relevant, my fork uses another config path so it can coexist with Flowplayer)
I’ll drop it here Flowplayer Experimental Fork.
Testing it out. Some immediate UX things I noticed:
  1. Icon is tiny on the screen. Probably doesn’t fill its bounding box.
  2. Music folder is not added by default, and you have to go into settings → Library → manage folders. Not obvious for new users.
  3. Most pages are laid out in a way that ignores the automagical notch handling on the JP2026.
Edit: Omni-search is amazingly useful.
Also random visual thing from the original FlowPlayer that annoyed me. Artists have no cover images, just a bunch of squares with names. Does the app handle this? Do I need to make some specific image for the artist in the folder? Maybe app can generate an image by taking album covers and making a mosaic out of them?
First and foremost, thanks for the feedback!
I start by saying I haven’t yet received approval nor support from the original authors, and this thread is marked as solved.
The now named Flowplayer-NG fork started as an experiment of mine, and I am still uncomfortable making the fork official due to the above.
Nevertheless, I am considering opening a new thread where this specific fork of mine is discussed as I believe FP has still a lot to give. At least this does not confuse new users expecting new features from the original Flowplayer.
That said, I am happy to answer your very appreciated questions:
  1. I haven’t had a chance to dig into it, I wonder if it’s the icon or the too long name
  2. very good point, I’ll see if I can introduce a tutorial or at least an automated step/default
  3. interesting. I’d like to know more about the handling you refer to. Any app in specific I can take inspiration from?
Happy to hear :smiley:
I don’t think that part was ever implemented in the original FP. For now, you can manually search for the artist picture from within the artist view pulldown menu.
I am thinking of implementing a background auto-scan of the artist pictures from last.fm or other providers. I like your idea of the mosaic :smiley:
Initial work was done for the album pictures, where my fork gets the embedded picture preferentially and falls back to a locally stored image if it finds one. I could try something similar for the artist.
The thing is, I have no idea if there’s a standard to handle this kind of cases. From my research there isn’t. I could try to do some regexp matching to find files like, for example, artistimage.jpg or cover.jpg. That could get out of hand :smiley:
How do you handle your collection and this kind of metadata/sidecar stuff?
I can see album covers for most of my music so there is support for it. There are to ways,
first to embed covers in music files and second via external images in folder. Most players has support for folder/cover.jpg/png files.
I have to check wich ones are visible.
I do have album covers, so those are fine. Just not artist images. But maybe I need to make these images?
Album covers are mostly handled at the moment.
About artist images: that would be an idea. But how would you name and store them?
artistimage.jpg?
Would you put them in each album directory with the tracks?
Store the albums under the same artist parent dir and put the artist image there?
I think the issue here is coming up with a decent standard. I could make Flowplayer manage more cases but without a standard it would just get out of hand, with nested evaluations and a scan job which could potentially get way less efficient.
We could pick a de-facto standard like what mp3tag does Mp3tag - Wikipedia.
Some ideas from this thread File Naming Convention |    The Audio Standard.
It’s a matter of tradeoffs.
Anyway, let me see what the original authors say and I’ll start a new thread. Thanks for the contributions so far!
I’ve done some work on flowplayer in the past and just haven’t had time with all the other apps I maintain. I would ask @olf if he has issues with it, but I’m willing to go through the commits which, on first inspection, look quite clean and discrete. It’s a bit of a large merge, but it would be nice to keep it in the community context since that makes it easier to contribute directly once you’ve done some work on it and can directly use the repository.
On the artist art front, you might look at theaudiodb which @cypherpunks also uses in his musicex … I has a nice ‘free tier’ api and it’s a site you can contribute to that I find easy to use.
For an idea of the available are …
curl  https://www.theaudiodb.com/api/v1/json/123/search.php?s=bjork  -H "Content-Type: application/json" | jq
     "strArtistThumb": "https://r2.theaudiodb.com/images/media/artist/thumb/wwrtws1349443266.jpg",
      "strArtistLogo": "https://r2.TheAudioDB.com/images/media/artist/logo/8c4lxd1729114688.png",
      "strArtistCutout": "https://r2.theaudiodb.com/images/media/artist/cutout/z48bme1665065374.png",
      "strArtistClearart": "https://r2.TheAudioDB.com/images/media/artist/clearart/efqxwg1729177219.png",
      "strArtistWideThumb": "https://r2.theaudiodb.com/images/media/artist/widethumb/e1nu3s1729177263.jpg",
      "strArtistFanart": "https://r2.theaudiodb.com/images/media/artist/fanart/vpupvx1349443243.jpg",
      "strArtistFanart2": "https://r2.theaudiodb.com/images/media/artist/fanart/yrpwvq1346240134.jpg",
      "strArtistFanart3": "https://r2.theaudiodb.com/images/media/artist/fanart/rq2rtq1729177322.jpg",
      "strArtistFanart4": "https://r2.theaudiodb.com/images/media/artist/fanart/g6vqvi1729253833.jpg",
      "strArtistBanner": "https://r2.theaudiodb.com/images/media/artist/banner/tuqqrs1346240166.jpg",
      "strMusicBrainzID": "87c5dedd-371d-4a53-9f7f-80522fb7f3cb",
Thanks for the audiodb tip and for chiming in :slight_smile:
I’ll continue some experimentation during the weekend.
Eager to hear Olf’s opinion too.
The other option for artist covers is to maybe pull from Unplayer, which I think just defaults to the first album cover it can find.
I did a bit of rework on this and pushed the changes yesterday.
  • There’s now a dedicated section to manage Album and Artist covers downloads, and stuff is pulled from TheAudioDb as suggested by poetaster.
  • Additionally, there’s now a first-run welcome screen to select the Music folder :slight_smile:
More work in the backlog, I’ll keep ironing out the bugs.
Great work, i always liked flowplayer.
I have a question/request. Since I use my DAP (Miio) a lot, i don’t have music on my sd card anymore. And that’s fine, but i miss a kind of Bubbleupnp musicplayer app. Where you can play local files, but also on a nas server (dlna/upnp). And it has also a renderer option, so I can play it trough wifi on my old (but golden) JK acoustics.
The question/request is: Is that an option for flowplayer? With flowplayer finding my flac music on my server and play it with renderers? (similar like the spotify connect option?)
Or am I way of with my request here? :slight_smile:
Ps: i have the bubbleupnp app and it works great, but I would like a native option
Great player since years and I really like havin my radio stations in there. Thanks
Selecting the folder drops me out of the app. Maybe because I havent music files in the selected folder?
Thanks
