Random network loss
REPRODUCIBILITY: Random, so no specific steps.
OS VERSION:5.2.0.17
HARDWARE:JP26 / hardwarerevision 1.0.0.17
UI LANGUAGE: Dutch
REGRESSION: ?
After a random amount of time apps (in any case the weather-app) looses networkconnectivity. Restarting the app seems to resolve this for a period of time. The weather-app in 'Events' is still without network and keeps saying 'tap to refresh' (or something similar).
Disabling wifi seems to resolve this.
Not sure.
  1. Just wait.
Apps keeping networkconnectivity.
Information is not refreshed and doesn´t get updated, despite refreshing.
Developer mode enabled.
Sshd enabled.
Community stores installed (Storeman, Chum).
Patchmanager installed (no patches installed).
Android AppSupport installed.
No audio- or WLAN-related system modifications.
I do not know if this is relevant, but here are some lines from dmesg.
After a lot of ‘polling conn_infra ID failed’ I disconnected wifi and reconnected and weather in ‘events’ could update again.
\[51620.756929\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51621.282969\] \[ T7946\] \[wlan\]\[7946\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51621.958655\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51622.757357\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51624.757205\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51625.030407\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51626.757722\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51627.267046\] \[ T8047\] \[wlan\]\[8047\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51628.102101\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51628.756541\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51629.244911\] \[ T3077\] \[wlan\]DUMP8 ADDRESS: 0x000000006952150b, Length: 5
\[51629.244950\] \[ T3077\] [wlan](0x000000006952150b) ff 03 02 00  2a
\[51629.256322\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51636.453904\] \[    C6\] \[wlan\]\[6138\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51636.758042\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51637.994537\] \[ T3077\] \[wlan\]DUMP8 ADDRESS: 0x000000006952150b, Length: 5
\[51637.994607\] \[ T3077\] [wlan](0x000000006952150b) ff 03 02 00  2a
\[51642.757799\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51646.757618\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51647.995545\] \[ T3077\] \[wlan\]DUMP8 ADDRESS: 0x000000006952150b, Length: 5
\[51647.995609\] \[ T3077\] [wlan](0x000000006952150b) ff 03 02 00  2a
\[51648.007093\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51650.757775\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51652.858119\] \[ T3160\] \[wlan\]\[3160\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51657.977808\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51658.024667\] \[ T3077\] \[wlan\]DUMP8 ADDRESS: 0x000000006952150b, Length: 5
\[51658.024737\] \[ T3077\] [wlan](0x000000006952150b) ff 03 02 00  2a
\[51658.036043\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51658.036539\] \[T57883\] \[wlan\]\[57883\]rlmDomainUpdateRegdomainFromaLocalDataBaseByCountryCode:(RLM ERROR) Cannot find the BE RegDomain. Set to default WW
\[51660.482538\] \[ T3077\] \[wlan\]DUMP8 ADDRESS: 0x000000006952150b, Length: 5
\[51660.482582\] \[ T3077\] [wlan](0x000000006952150b) ff 03 02 00  2a
\[51660.493980\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51660.535864\] \[ T3077\] \[wlan\]\[3077\]aisSearchPmkidEntry:(AIS ERROR) prStaRec is NULL!
\[51660.568060\] \[ T3077\] \[wlan\]\[3077\]kalIndicateDriverEvent:(INIT ERROR) event to cfg80211\[id:8\]\[len:1\]\[F:1\]:7
\[51660.573849\] \[ T3077\] \[wlan\]\[3077\]wlanChipCommand:(REQ ERROR) wlan ret=259
\[51662.755808\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51664.756792\] \[ T3078\] \[wlan\]\[3078\]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
\[51665.484524\] \[ T3077\] \[wlan\]DUMP8 ADDRESS: 0x000000006952150b, Length: 5
\[51665.484585\] \[ T3077\] [wlan](0x000000006952150b) ff 03 02 00  2a
\[51665.875033\] \[ T3075\] \[wlan\]\[3075\]qmReleaseCHAtFinishedDhcp:(QM ERROR) No channel occupation
I have a Situation active that connects wireguard-vpn automatically when I leave my home-wlan and disconnects wireguard when I connect to my home wlan again.
It appears to happen after disconnecting wireguard.
I will check this some more today and add my findings.
Hi, had the same problem after updating to 5.2.0.22
Disabling WiFi seems to work to prevent random 4G disconnection
Cheeerzzz !
I’ve experienced this too, JP2026 on 5.2.0.22 (only version I’ve run on it so I have no idea if it’s a regression). Disabling wifi does seem to fix it. I’m not sure if me living in a place with awful coverage impacts it but I was walking around my house and it suddenly came back on LTE by itself. I’m having to have the wifi off for now or I can’t receive calls reliably. Not great since I’m on call 24/7.
